Author Topic: [GB] M93I, A 87% Keyboard kit with Numpad Ends in 4 hours  (Read 5523 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« on: Mon, 31 October 2022, 01:37:48 »
Hi Everyone,
Thank you for following this project! M93I GB is live now.  :cool:
M93I Keyboard Kit Highlights
  • Cluster Shortened Numpad and Utility keys: M93I keyboard kit retains the basic F-zone and the Home, End, PG UP, and PG DN keys, while adding a numpad area for easy data entry
  • Pen Holder: JOJO team designed a pen holder at the top of M93I keyboard to place stationery such as pens.
M93I Gallery
GB Time: Oct.26th - Nov.9th,2022
Delivery time: Start packing and sending to Wuque Studio direct customers in Q2, 2023.
GB Product Page
GB Price:
- White Navy (Top case: E-white; Bottom case: Blue Anodized): 289 USD
- Black (Anodized): 269 USD
- Navy (Anodized): 269 USD
* Typing Sound Test
Streamers/Youtubers
* Alexotos - M93I Navy keyboard kit
* Xingxing wong - M93I Navy keyboard kit
* Apiary - M93I White Navy keyboard kit (Top case: White; Bottom case: Blue ,Time: TBD)
* Clackbait - M93I White Navy keyboard kit (Top case: White; Bottom case: Blue ,Time: TBD)
Specifications
Typing angle: 5.5 degrees
Dimension: 363 x 147 x (20-30) mm
Front Height: 20mm
Weight (unbuilt): 1.7 kg
Case Material: 6063 Aluminum
Mounting Method: Top Mount
Supports ANSI Layout only
PCB Specifications:
- 1.2mm Hot-swap PCB
- Stepped Caps Lock Supported
- VIA supported
- ESD Protection
M93I Kit Contents:
* Aluminium Top and Bottom Cases
* PC Plate
* Hot-swap PCB
* Plate Poron foam
* Poron Foam under PCB
* PE switch poron foam
* LED diffuser
* Type C module
* Keyboard feet
* PCB JST cable
* Hex screwdriver
If you are interested in this kit and/or have any suggestions, please fill in the M93I IC form and join the M93I  discord channel in Wuque Studio’s Discord server.
Thank you!
« Last Edit: Wed, 09 November 2022, 20:52:05 by Ckeeb »
Re: [GB] M93I, A 87% Keyboard kit with Numpad
« Reply #1 on: Mon, 31 October 2022, 12:36:56 »
Approved :thumb:
Offline ChitownM2
« Reply #2 on: Mon, 31 October 2022, 16:07:20 »
Might have been interested in this, but without an enter key, the numpad is useless.
Offline Nevrest
« Reply #3 on: Mon, 31 October 2022, 19:57:57 »
I have to agree with this sadly, other than that I am a big fan.
Offline Ckeeb
    • MELETRIX
« Reply #4 on: Tue, 01 November 2022, 05:41:42 »
Offline Ckeeb
    • MELETRIX
« Reply #5 on: Wed, 09 November 2022, 20:51:38 »
Sorry. Thank you for your suggestions.
Offline kbsomarks
« Reply #6 on: Fri, 11 November 2022, 07:08:59 »
Still willing to give this a go, but yes really don't understand why no enter key on the numpad
