Author Topic: How to contact a Group Buy organizer or vendor  (Read 116791 times)
« on: Fri, 04 November 2022, 14:00:27 »
First, determine who is the best person to contact regarding your request
  • If you have a fulfillment question and the Group Buy has regional vendors acting as proxies, your regional vendor is most likely who you need to reach out to; they should have a contact system on their site (or discord in some cases)
  • If the GB in question is being fulfilled by the person who created the thread on GH, then you'll want to PM the thread creator directly; I highly recommend enabling "Save a copy of each personal message in my sent items by default" (detailed below)
Whether you're contacting a vendor or designer/runner, there are some helpful tips to keep in mind to make things easier for everyone involved
  • Include the GB name in the subject line
  • Include your order number in the message body
  • Quote prior messages or provide context to any previous discussions you might have had on the topic you're messaging about
  • Clearly articulate what you are asking for or requesting
  • Be polite (this should go without saying) - most vendors and designers are small operations and may not respond immediately like you've come to expect from massive online retailers; if you need to send a follow-up message, do so, but give a little leeway unless you have good reason to be upset
How to enable "Save a copy of each personal message in my sent items by default" (this will allow you to verify that the message you clicked "Send" on did in fact send)
  • Click 'Messages' in the top bar
  • Hover over 'Preferences' (tap 'Preferences' on mobile) to bring up the Preferences menu
  • Click 'Change Settings'
  • Check the box next to 'Save a copy of each personal message in my sent items by default.' (second item from the bottom)
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: How to contact a Group Buy organizer or vendor
« Reply #1 on: Fri, 04 November 2022, 15:06:32 »
 :thumb:
Offline Bic
« Reply #2 on: Mon, 19 December 2022, 06:02:52 »
:thumb:
« Last Edit: Mon, 19 December 2022, 06:35:24 by Bic »
Tofu65 with Durock T1 and SA Chalk    Waka60, gat yellows and KbdFans DSA
Offline smithcohn12
    • unlimited wordle
« Reply #3 on: Wed, 08 January 2025, 04:07:06 »
Thanks for the detailed guide! Following these steps makes contacting a Group Buy organizer or vendor much easier and ensures clear communication.
