Author Topic: [GB] V65 R2 - Entry-level King just gets better! (Aluminum 65% with Knob)  (Read 15200 times)
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
FinalKey V65 R2
Entry-level 65% Aluminum Kits
Bluetooth Ready
(with Knobs and Keycaps)
(Available Worldwide)
The R1 of V65 has sold out in minutes after sales on different platforms in SEA and China. And now, the R2 is ready for you, the enthusiasts, to explore other possibilities with new improvements that make the V65 all-time favorite aluminum alloy budget kit. Iconlabs is honored to be an official vendor of FinalKey, to bring this goodness to the mass.
Group Buy Info:
Starting: 1AM, November-05-2022
Ending: 12PM, November-12-2022
V65 R2 GB is now available via our store.
Thank you for your time and hope you enjoy this new product from FinalKey
From Iconlabs with love :-*.
https://iconlabsofficial.com/product/gb-v65-r2-kit-from-finalkey/.
Estimated Fulfillment Day:
Mid to Late December, 2022
Price: $115 for all color options.
Shhhh: Limited discount can be found!
V65 R2 features:
  • 65% Standard Layout with a knob
  • VIA supported PCB with encoder
  • Aluminum alloy case with 3 colors. All CNC and powder coated.
  • Gasket mount (poron)
  • Included plate foam and case foam (all poron)
  • Included IXPE PCB foam
  • 2 modes: Wired + Bluetooth
  • South-facing per-key LEDs
  • Hot-swappable
  • Included keycaps.
  • Included screw-in stabilizers
  • USB-C daughterboard for maximum flex
  • PC Plate & FR4 Plate
  • ABS Doubleshot Translucent Keycaps included (comes with default color depending on your case choice)
Yes, you don't read it wrong, a whole set of keycap is included when you purchase this V65 kit. And it's translucent ABS doubleshot!
Let's enjoy the soundtest videos from R1 users.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] V65 R2 - Entry-level King just gets better! (Aluminum 65% with Knob)
« Reply #1 on: Sun, 06 November 2022, 15:30:14 »
Approved
    • Iconlabs
« Reply #2 on: Tue, 08 November 2022, 02:04:25 »
Update: Now you can buy extra knob with your V65 kit for extra spice  :p :))
Offline MarkoFloro
« Reply #3 on: Tue, 08 November 2022, 07:36:20 »
Entry level has really upped its game this sort of design would have been unheard of not long ago. Really glad something like this is on the market
    • Iconlabs
« Reply #4 on: Wed, 09 November 2022, 10:19:58 »
FinalKey did step up their game and this V65 R2 deserves better recognition we believe!
Offline PlayBox
« Reply #5 on: Wed, 09 November 2022, 15:10:24 »
for an entry level king it should be top mounted, so many entry levels that are gasket mounted but not so much top mounted ones
propably sent from my amazon kindle 10th gen
    • Iconlabs
« Reply #6 on: Wed, 09 November 2022, 20:14:43 »
Top mount is for more experienced user I believe. Gasket mount is easier to manufacture for maker and also easier to implement for entry level users. We personally would love to ask for a top mount option with a reasonable increase in price.   :llama: Too bad they are still considering it.
« Last Edit: Thu, 10 November 2022, 05:23:52 by IconlabsOfficial »
    • Iconlabs
« Reply #7 on: Fri, 11 November 2022, 07:21:50 »
Last day! Hurry up everyone!  :thumb:
« Reply #8 on: Fri, 11 November 2022, 14:48:05 »
Is the white color white or silver?
MAAASSSSDDDRROOOPPPPPP!!!!!
    • Iconlabs
« Reply #9 on: Fri, 11 November 2022, 15:46:16 »
It's more white than silver :D A bit of reflection on the white case does make it looks like silver, but it's still white, a smooth white
    • Iconlabs
« Reply #10 on: Fri, 16 December 2022, 08:27:49 »
All kits will be ready to shipped next week!
    • Iconlabs
« Reply #11 on: Fri, 23 December 2022, 06:10:02 »
Orders are being fulfilled. Tracking number will be updated in few hours
    • Iconlabs
Re: [GB] Aluminum kit FinalKey V65 R2 - Group Buy Round 2
« Reply #12 on: Mon, 09 January 2023, 10:18:36 »
Wowwww
The quality of V65 R2 is just out-standing among other keyboards in the same price range. We must admit this is a must-have in anyone’s collection.
With people’s demand to host another GB, we decided to run the next GB for only 3 days with limited kits.
=== GROUP BUY INFO ===
- From Jan 11th to Jan 13th, 2023
- GB Link: https://iconlabsofficial.com/product/gb-v65-r2-kit-from-finalkey/
Price: $105 $95 for all color options.
Estimated fulfillment day: February 15th, 2023
=== UNBOXING VIDEOS ===
=== SOUND TEST ===
You can see testimonials for yourself:
=== SPECS ===
V65 R2 features:
- 65% Standard Layout with a knob
- VIA supported PCB with encoder
- Aluminum alloy case with 3 colors. All CNC and powder coated.
- Gasket mount (poron)
- Included plate foam and case foam (all poron)
- Included IXPE PCB foam
- 2 modes: Wired + Bluetooth
- South-facing per-key LEDs
- Hot-swappable
- Including keycaps.
- Including screw-in stabilizers (good ones)
- USB-C daughterboard for maximum flex
- PC Plate + FR4 Plate
- ABS Doubleshot Translucent Keycaps included (comes with default color depending on your case choice)
Thank you for your time and hope you can get this V65 R2 keeb!
From Iconlabs with love!
« Last Edit: Mon, 09 January 2023, 10:23:30 by IconlabsOfficial »
