Author Topic: G81-7000hpbus-2 new  (Read 2545 times)
Offline Phaedrus2129
G81-7000hpbus-2 new
« on: Wed, 29 September 2010, 23:14:39 »
New doubleshot donor boards, same model as the ones I'm pulling. These are apparently "open box", meaning they were sold then returned with little or no use. The seller has 10+, so it's a reliable source.
http://cgi.ebay.com/New-CHERRY-MY-7000-POS-Credit-Card-P-S-2-Black-Keyboard-/390239663544?pt=PCA_Mice_Trackballs&hash=item5adc18b5b8
On the downside, they're $49.99+S&H. Ouch. I've only got one set left though, so this may be the only large source for a while.
Also, another one:
http://cgi.ebay.com/Cherry-Keyboard-Credit-Card-Reader-MY-7000-Black-NEW-/120538753526?pt=LH_DefaultDomain_0&hash=item1c10ab69f6
G81-7910HPBUS-2 this time. I'm not sure what the difference is. These are cheaper, and aren't labeled as "open box".
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Zen
G81-7000hpbus-2 new
« Reply #1 on: Thu, 30 September 2010, 03:57:01 »
Yeah, I saw those from Goodmans, they where on sale for $25something at one time ..
Freight to my country is 40 bucks for one, plus 30 bucks for customs processing plus
25% sales tax . So, it would end up costing me something like 125 bucks .....
A bunch of loose keycaps would probably go straight through customs without any salestax
so if you buy some of them Im interested ...
PS :
I believe the 7910 was made for Dell, based on this :
http://www.geminicomputersinc.com/g81-7910hpbus-2.html
« Last Edit: Thu, 30 September 2010, 04:00:46 by Zen »
Offline celery
G81-7000hpbus-2 new
« Reply #2 on: Thu, 30 September 2010, 18:26:50 »
Hey Phaedrus, question about the profiles for the arrow key and insert/delete/home/end/pgup/pgdn cluster keycaps on this board. Do they match the profiles of the keys on a normal layout, with left, down, and right matching the bottom row; up matching the ZXC row; delete matching QWE, and insert matching the number row?
G81-7000hpbus-2 new
« Reply #3 on: Thu, 30 September 2010, 18:37:15 »
If you run your finger horizontally across one row all keys you hit will be the same profile. The Delete row is the same profile as the Insert/Function row.
