Author Topic: [IC] NEW PROFILE ---EMA Profile --- A NEW GOOD CHOICE FOR SPHERICAL KEYCAP  (Read 5377 times)
Offline rainson
    • IDOBAO_Studio
EMA Profile Keycap
Discord Server for More Updates Here
Google Form for IC
(Leave your important opinion here after checking)
Design Story
The EMA keycap is a new profile that IDOBAO spent a year re-adjusting. We reduced the height to make it more in line with the typing habits of most people.There is no need to use the wrist rest because of the higher keycap and the more ergonomic design can easily relax the wrist, you will not feel tired when typing for a long time. Similarly, we increased the face of keys to the width of the surface makes its contact surface larger, so that the fingers can also be in good contact with the key surface during blind tapping.
Compared with other spherical keycap
Compared with SA profile to reduced the height by 3.5MM and increased the face of keys by 16.6%;
compared with MT3 profile to reduced the height by 2.5MM and increased the face of keys by 25%;
compared with ASA profile to reduced the height by 1.5MM and increased the face of keys by 14.8%,
compared with MDA profile to increase the height by 1.5MM and reduced the face of keys by 5%.
Updates
Product Design
Sample produce
1st Round Sample Test
IC & Improve
2nd Round Sample Test
IC
Latest News
1.First minimalist black and white kit update online now
2.Could get $5off here:GAXWGQZDC85Y
Color
Minimalist Pure White
Minimalist Pure Black
Elf of Winter
Specifics
Profile:EMA Profile
Height:10.84-13.85mm
Width:18.2 * 18.2 mm
Thickness:1.5mm
Tech:Doubleshot
Material:PBT
Theme:Minimalist Pure white / Minimalist Pure Black / Elf of Winter
Keys:141 Keys
R4 Size
Please Join our Discord to make sure can get earlier and more updates
Please leave your thoughts here
Thanks & Regards
Rainson
« Last Edit: Thu, 17 November 2022, 00:10:51 by rainson »
Offline purryoverlord
Re: [IC] NEW PROFILE ---EMA Profile --- A NEW GOOD CHOICE FOR SPHERICAL KEYCAP
« Reply #1 on: Wed, 09 November 2022, 07:37:57 »
so is it uniform? there's no picture of the keycaps on their side so we can see the actual profile, no photos comparing to other profiles, the written comparison doesn't say which row you're comparing to ...
Offline rainson
    • IDOBAO_Studio
« Reply #2 on: Wed, 09 November 2022, 08:13:45 »
the comparison of the face of keys [everykey],the comparison of the height is R4,the side picture have updated
« Last Edit: Wed, 09 November 2022, 20:37:53 by rainson »
Offline gomezstevens
« Reply #3 on: Mon, 14 November 2022, 13:32:30 »
There are quite a few new technologies. I think you should check the compatibility with the keyboard before owning it.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #4 on: Mon, 14 November 2022, 22:53:11 »
Are these the row numbers from left to right in the profile picture?
  R0, R1, R2, R3, R4, R4
With a very small height adjustment, R3 could be exactly the same tool as R2, just turn the legends upside down.
Offline rainson
    • IDOBAO_Studio
« Reply #5 on: Wed, 16 November 2022, 23:47:04 »
thats right what you said,
the keycaps from left to right can understand as from up to down on the keyboard,
can be see as "R0, R1, R2, R3, R4, R4" or "R5, R4, R3, R2, R1, R1" ,
and the R3 nearly the same with R4 you mentioned is the biggest upgrate in this keycap, the change makes typing more confortable and could quickly suits in this keycap profile when you use and touch the keycapu. It is a little change of the spherical keycap but big experience change in using.
