Author Topic: Smart68 programming  (Read 3703 times)
Offline dzugashvili
Smart68 programming
« on: Wed, 09 November 2022, 11:51:55 »
Hey I know not many people ended up with one and there were a lot of shenanigans from feng that actually led to his departure from here. I finally took time to fix my missing hotswap socket after locating something that would fit and work.... anyways I did that a few months ago and then put it away cause my caps are messed up for a couple where i burned with with a soldering iron. The post is missing from here for the instructions on how to program the board and I was hoping someone might be able to educate me on what I need to do to reprogram the keys. I work through vmware  and can't install ahk on those so ahk would be useless as a solution if I was wanting to use this for more than leisure.
Thank you in advance for any responses! I normally used my model f remake or hhkb the but wanted to hop on some zealios again for once.
