Author Topic: [IC]Touch68-68% PCB Gasket Mount Custom Keyboard---Upgraded to Bluetooth PCB  (Read 4661 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi Everyone,
We are pleased to tell you that we have upgraded the PCB to Bluetooth PCB. We also added a new color - Wine Red. We hope you will like it!
Touch68 INFO
Touch68 PCB Gasket Mount Custom Keyboard, which G-Square studio designed and produced.
It adopts the bottom and side weight for decorating to look good and for a better typing feel.
The PCB and the plate have been designed with many flexes cuts to ensure a soft typing feel and premium typing sound experience.
It adopts the RGB strip circle around the side weight, which defuses nicely and brightly
RGB per key, which makes your fingers dance on the keyboard and makes the keyboard look more stunningly
Render UPDATES
Prototype UPDATES
Specifications:
6063 CNC Alu case
RGB strip
Typing angle: 6°
PCB GASKETS structure
QMK/VIA Supported
Anti-ghost Custom
PCB gasket socks
Type-C
Wired
Poron Dampening pads
A Set of hexagon screws
Big keyboard cleaning cloth
Support PCB stabilizers
Case Colorway: White, Milky-White, Black, Blue, Grey, Pink, Wine Red
PVD Brass Weight Colorway: Gold, Silver, Black, Chroma
Upgraded Bluetooth PCB's options and specifications
Flex cut Bluetooth hotswap PCB without key RGB support ANSI layout(Compatible with Step Capslock)
Key RGB Bluetooth hotswap PCB without flex cut design support ANSI layout (Compatible with Step Capslock)
Flex cut solder Bluetooth PCB without key RGB support ANSI and IOS layout
Plate options and specifications:PC、POM、ALU、FR4
All the plates are with flex cut design.
Price:Under USD300
We are working to handle all details, to let you have a more good experience with this keyboard.
Please fill in below IC form with your idea and make it better and better.
Your idea matters! Thank you!
Mykeyclub is a platform that integrates creativity and innovative design,
helping more studios join this hobby community and bringing you guys more fun and cool products.
For more discussions and future updates, please join Mykeyclub discord.
Thank you for your time.
Best wishes to you
Mykeyclub Team
Offline Xury46
Exciting to see the updates.
I would still love to see an alternative split spacebar layout with 1.25u mods on the left side while retaining the 1u arrow keys on the right. I'm not picky about the way the spacebar gets split, personally I don't need the 1u space in between the two halves.
Do you have renders of the blue case?
Offline Toptiginn
    • toptiginn.com
Black one is so good :cool:
