Author Topic: [GB] The NUM1 - GB Canceled. MOQ not met :(  (Read 7136 times)
Offline Friendship
« on: Sat, 12 November 2022, 17:44:23 »
[ The NUM1 ]
A gummy o-ring mounted number pad with a Daughterboard, Bluetooth, alternative top mount, and Alps compatibility.
V2 and V2.5 prototype photos:
[ The Group Buy information ]
Vendor: https://thockeys.com
Price: $250 for the kit
Sale format: Raffle
Raffle entry period: now closed
Fulfillment estimation: 4-6 months from GB wrap up (very generous, but I just want to be safe)
Extras:
$12 - MX PP Plate - Cut by the wonderful Jake at the https://p3dstore.com
$18 - Alu Alps Plate - "jack" anodization color
$30 - PCB
$5 - O-ring 50A
[ The Kit ]
- NUM1 case top (color choices below)
- NUM1 case bottom Silver Anodization
- Sandblasted brass weight
- Mx 5052 Aluminum Plate ("Jack" anodization color)
- 1.6mm PCB (designed by TrifeLife)
- Daughter board (Unified C3 design)
- 1x JST cable
- 1x 50a O-ring
- Hardware
- 3M bumpons
[ The Colors ]
PROTOTYPE PHOTOS NOT THE FINAL GB COLORS. PLEASE CLICK MORE FOR THE MANU COLOR CHIP
"Ron"
more views and Manu color chip:
"Gump"
"Jack"
[ The Specs ]
Angle: 6.5 degrees
MX plate material: semi-transparent polypropylene OR anodized "Jack" 5052 aluminum
Alps Plate material: Anodized "jack" 5052 aluminum
Firmware: ZMK
Battery life: ZMK estimates 2-4 weeks
Built weight: ~1.3 Lbs
The LiPo battery sized for this cavity is identified with the criteria below:
capacity: 150 mAh
Voltage: 3.7 V
connector: Micro JST SH 1.0mm
[ The Sound tests ]
Proto 2 sound tests:
Cherry on Alu
https://clips.twitch.tv/AffluentSaltyKangarooPRChase-hpdV_1uDCvYN2_Fa
Cherry on PP
https://clips.twitch.tv/HilariousAbnegateWerewolfDxAbomb-Rr_5XkRev7v9-Uz-
[ The Special thanks ]
TrifeLife
Maly
Yataomi
Choobies
The MLI homies
This lil guy: https://i.imgur.com/5znfuGO.jpg
Thank you all for being my friends :)
Sincerely yours, your friend,
- Friendship
[ The Discord ]
https://discord.gg/NW8txQcnA8
Old IC stuff:
[ The Inspiration ]
This was born from being disappointed in the lack of premium numpad options available at the time of initial design as well as age old instigating questions like "what if we slapped an o-ring into it?" and "what if we slapped bluetooth into it".
More ramblings of context:
I was also influenced by one of my favorite kustoms the GHv2 by LZ.
The engraving and name was born from some cheeky wordplay of songs by one of my favorite artists Machinedrum. I binged his music throughout this design process and felt inclined to immortalize it within the design. His use of numbers in his song names also integrated well into the theme of the numpad.
NUM1: a play on 'Come1' off the album “Room(s)”
Only 1 Way 2 Numpad: a play on 'Only 1 Way 2 Know' off the album “Vapor City Archives”
I was made aware only somewhat recently that a fellow member of this community HineyBush designed the TKL ONE and the NUM ONE (I knew the TKL ONE but didnt know it had a numpad!). Given the name is nearly identical, I reached out to Hiney for permission to continue use of the NUM1 name for this project, He approved! :D Thanks Mr. Hiney!
« Last Edit: Fri, 25 November 2022, 20:45:41 by Friendship »
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Re: [GB] The NUM1 - Gummy O-ring BT NumPad - GB from NOV 19-22!
« Reply #1 on: Mon, 14 November 2022, 09:53:22 »
Approved :thumb:
Offline Friendship
Offline willowt
« Reply #3 on: Mon, 14 November 2022, 10:56:25 »
Sick numpad! Is there any chance for any kind of SS or polished weight?
Offline Friendship
« Reply #4 on: Mon, 14 November 2022, 11:36:38 »
Thank you so much!
Unfortunately sandblasted brass only for this run. But there is a possibility that I may do a weight mini run in the future if there is interest! I was quite a fan of the Mirror SS weight myself
Offline Kwub
« Reply #5 on: Mon, 14 November 2022, 12:04:54 »
super hyped for this!
Offline Razer1987
« Reply #6 on: Mon, 14 November 2022, 12:07:08 »
Hi, any ref for the bluetooth battery to get an idea of how much it costs? Ty
Offline Friendship
« Reply #7 on: Mon, 14 November 2022, 12:53:42 »
<3<3<3
excellent question! The LiPo battery sized for this cavity is identified with the criteria below:
capacity: 150 mAh
Voltage: 3.7 V
For USA buyers: https://tinycircuits.com/products/lithium-ion-polymer-battery-3-7v-150mah
potential sources for International purchasers: see my discord or PM me, the links are comically long and i dont want to do a short url
information will also be updated on my Discord and in the GB post
« Last Edit: Mon, 14 November 2022, 18:02:37 by Friendship »
Offline Friendship
« Reply #8 on: Fri, 18 November 2022, 23:01:37 »
« Last Edit: Sat, 19 November 2022, 09:15:10 by Friendship »
Offline Friendship
Re: [GB] The NUM1 - Gummy O-ring BT NumPad - GB raffle form live until NOV 22!
« Reply #9 on: Tue, 22 November 2022, 09:34:31 »
Hey everybody, today is the last day for the raffle! Numbers are looking good as well :)
I appreciate everyone's consideration and support!
Offline Friendship
Re: [GB] The NUM1 - GB raffle closed :)
« Reply #10 on: Tue, 22 November 2022, 23:10:40 »
GB raffle form is now closed and we have enough folks to proceed, THANK YOU EVERYONE! I will announce here when all of the winning emails have been sent out over the next day or two!
Offline Friendship
Re: [GB] The NUM1 - GB raffle now closed :)
« Reply #11 on: Wed, 23 November 2022, 09:44:42 »
Emails have been sent out to the winners! Check ya emails y'all!
Offline Friendship
Re: [GB] The NUM1 - GB Canceled. MOQ not met :(
« Reply #12 on: Fri, 25 November 2022, 20:46:41 »
reposting from my discord:
With a heavy heart I have to let everyone know that we didnt get enough orders to meet the MOQ. i had planned for some percentage of unpaid winners but i didnt expect more than the reroll pool. even my unit and the few FNF units couldn't close the gap.
For those that did purchase, you will be getting a refund over the next few days, and from the bottom of my heart thank you so much for your dedication and support.
I'm not sure what to do now to be honest but the future is usually foggy until its right in front of you.
thank you all.
Offline alper_maestro
« Reply #13 on: Thu, 01 December 2022, 07:41:01 »
Way too expensive for a numpad otherwise more people would gain one. Looks nice man but the price is killing.
Good luck in the future.
