Author Topic: Box of chocolates  (Read 4284 times)
Offline TexasFlood
Box of chocolates
« on: Thu, 30 September 2010, 20:58:10 »
For your buying/bidding pleasure, cheap and/or BIN items, pick your favorite flavor...
UNICOMP KEYBOARD WITH TRACKBALL MODEL M5-2 BIN $34.95
WARNING! The above Unicomp on-the-ball is rubber dome! So don't bid unless that's what you want!
[strike]Chicony blue Monterey Silders Clicky Mechanical KB-5181 BIN $19.99$14.99 - Price lowered![/strike] - Finally somebody bought it!
Logitech Trackman Marble Trackball Mouse PS2 PS/2 BIN $14.99
[strike]Classic IBM "clicky" Keyboard - 52G8700 FRU 92F0332 1 bid $4.99[/strike] Sold for $10.50+$9.50 shipping.
[strike]Vintage IBM Blue Logo Model M Keyboard 1-27-96 Clicky 1 bid $0.99[/strike]
« Last Edit: Sat, 09 October 2010, 20:04:41 by TexasFlood »
Offline TexasFlood
Box of keyboard chocolates
« Reply #1 on: Sun, 03 October 2010, 13:50:58 »
Nobody wants a chocolate? Take two, they're small!
« Reply #2 on: Sun, 03 October 2010, 14:02:47 »
Awww, I thought you meant literally ... I want chocolate.
Offline TexasFlood
« Reply #3 on: Sun, 03 October 2010, 20:22:23 »
Quote from: Findecanor;229321
Sorry about that, the chocolate was metaphorical.
Offline jpc
« Reply #4 on: Sun, 03 October 2010, 21:13:57 »
Caution, I think the Unicomp M5-2 might be rubber dome.
The seller says its a 96U114.  I cannot find reference to any part 96U114.  There is a 96U1114, and that is a rubber dome board, clickkeyboards lists it as rubber domes.
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline TexasFlood
« Reply #5 on: Sun, 03 October 2010, 21:26:54 »
Quote from: jpc;229437
Thanks for the warning.  Insight lists the 96U1114 as buckling spring (on the Tech Specs tab), but I'd probably trust clickkeyboards unless proven otherwise.
Offline TexasFlood
« Reply #6 on: Tue, 05 October 2010, 13:49:20 »
Quote from: TexasFlood;228593
FYI, I bought one just like this from this seller and just got it in.  It's yellowed on the right side no doubt from prolonged sun exposure from that angle, so probably a candidate for retr0bright at some point but works fine.  I read some old posts from iMav gushing about these as "best external pointing device" so had to try it but didn't want to spend as much as these were going for.  These BIN ones seemed like a good way to do that.  I can live with the yellowing for now and hopefully can fix it at some point.  And I do like it, although it's a bit different from what I'm used to.  Giving it some time to see if I can adjust to it being really comfortable which I am optimistic about right now.
Offline Phaedrus2129
« Reply #7 on: Tue, 05 October 2010, 15:41:43 »
I'd like a box of chocolates arranged like the keys on a keyboard, with a red gumdrop for escape.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline TexasFlood
« Reply #8 on: Tue, 05 October 2010, 15:53:32 »
Quote from: Phaedrus2129;230097
Here you go, have to supply your own gumdrop though.
I could edit one in later but don't have time right now, :wink:.
Offline jpc
« Reply #9 on: Thu, 07 October 2010, 22:40:51 »
I just asked the seller of the Unicomp M5-2 whether it's buckling spring or rubber dome.
Offline TexasFlood
« Reply #10 on: Fri, 08 October 2010, 15:47:38 »
Quote from: jpc;231165
Thanks, let us know what you hear back...
Offline jpc
« Reply #11 on: Fri, 08 October 2010, 15:56:30 »
Seller says it's rubber dome.
I thought my question would appear on the ad; but apparently I didn't manage to ask it publicly.
Offline TexasFlood
« Reply #12 on: Fri, 08 October 2010, 16:10:11 »
Quote from: jpc;231520
OK, bummer, thanks, I updated my post above...
