Author Topic: HELP Linux key shortcut to a weblink  (Read 3120 times)
Offline Meliodams
« on: Thu, 24 November 2022, 11:25:42 »
HI
I would want to know if  is it possibie to reaffect keyboard keys directly to a weblink on Ubuntu? And how?
Example; Press page up become github.com
Thank you  :thumb:
Re: HELP Linux key shortcut to a weblink
« Reply #1 on: Fri, 25 November 2022, 04:00:16 »
Yes, definitely possible.
How would depend on your GUI - I'm using XFCE and to do this I'd click settings in the menu then keyboard and it's obvious from there :)
Offline Meliodams
« Reply #2 on: Fri, 25 November 2022, 04:59:56 »
It's definitely what i needed !
Thanks a lot  :thumb:
Ediit: I have the impression, on destkop Ubuntu, you can't directly make a shortcut without ctrl + or alt +
« Last Edit: Fri, 25 November 2022, 06:07:56 by Meliodams »
« Reply #3 on: Fri, 25 November 2022, 19:34:33 »
That is unfortunate.  You could change the print screen key to send ctrl+ print screen using xkb then map that using the GUI?  Depends what you are actually trying to do whether this is viable...
