Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Interest Checks
(Moderator:
Signature
[IC] Epomaker Type65 - 65% kit with Alu Case, VIA, Bridge Gasket mounted
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [IC] Epomaker Type65 - 65% kit with Alu Case, VIA, Bridge Gasket mounted (Read 3950 times)
EpomakerKeyboard
Thread Starter
on:
Mon, 05 December 2022, 01:53:41 »
Hi Everyone,
We have been working on
Type65
for months and it's time to show it to you guys!
Epomaker Type 65 DIY Kit is a 65% multi-functional wired keyboard from a designed idea by
Facts Eliminator
. The barebones kit is designed with different features of Bridge-Gasket Mount, QMK/VIA Programmable, Hot-swappable with South-oriented Switches, PC Plate & Aluminum Case, Screw-in Stabilizers!
We have applied a new gasket type into this board - bridge gasket. This kind of gasket can add more bouncing feel to typing.
As to the badge on the right, it can be customized and engraved by different pattern. We may put on another poll to choose the patterns in the future, or not (if we do not receive enough responses in the
IC form
The PCB does not have LEDs so that won't be backlights. We've been thinking a lot on if we should add LEDs to the PCB or not. The final conclusion is that we should skip backlights for this keyboard to keep the it neat and bug-less.
Apart from the white-purple color scheme, there will also be black-orange, navy-grey and pink to suit different customized keycap sets.
If you have any other thoughts on this keyboard, feel free to fill our
IC form
Join
our discord
to get more updates!
Estimated GB Date: TBC
Space-saving 65% Layout
Aluminum Case
Bridge Gasket Mount
PC Plate
Support Screw-in Stabs
Support South-facing Switches
More Colors Available
Assembed Type65
The badge on the right can be changed to two keys
The bridge gasket is a new type to support and be bouncing even with stiff plates
PC plate and Poron form kits: PCB foam, switch sheet & bottom foam
At last, we made a video to show how to disassemble the keyboard and replace badge:
Last Edit: Mon, 05 December 2022, 04:36:26 by EpomakerKeyboard
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Interest Checks
(Moderator:
Signature
