Author Topic: HHKB Hybrid Type-S question  (Read 3561 times)
Offline macguy80
« on: Fri, 09 December 2022, 23:19:59 »
In his review of the HHKB Professional 2 Type-S, @chyros points out that they forgot to silence the space bar, which is "absolutely deafening" in comparison to the rest of the keys. As the owner of one myself, I can't agree more.
Did they fix this in the Hybrid Type-S, or does that flaw persist?
Offline achooie
Re: HHKB Hybrid Type-S question
« Reply #1 on: Wed, 14 December 2022, 00:08:38 »
Yeah the pro hybrid type-s is mostly fixed. My type-s was manufactured on 2022-05-24 and its spacebar makes a deep, muted thock, though sometimes there's a bit of a squeak (which is why I say mostly, see reddit). It's quiet enough that I'm not bothered enough to mod it. The stock lubrication on the stabilizers has been plenty quiet too, for the record.
Planck Zealios 67g | Leopold FC900R | Apple M0116 Alps Salmon (ADB converter) | HHKB Pro HYBRID Type-S
Offline macguy80
« Reply #2 on: Wed, 14 December 2022, 14:17:19 »
Thanks! I could definitely live with that squeak, as compared to the jarring thunk of a totally unsilenced spacebar.
