Author Topic: Optical Switches for GK61 and similar  (Read 2813 times)
Offline Subdromat
« on: Sat, 17 December 2022, 10:42:21 »
Hello,
iam figuring out if there are eventually more choices of optical switches for GK61 PCB:
The board is equipprd with Gateron Opticals. Looks like Gateron Opticals are interchangeable with
Kailh Opticals and Outemu Opticals. Maybe modifying is possible or there is a trick using other optical switches.
The point is obviously the sensor setting on the specific PCB.
Tx
Offline PlayBox
Re: Optical Switches for GK61 and similar
« Reply #1 on: Mon, 19 December 2022, 10:24:55 »
Hello,
Tx
sadly the optical market is small and these are basically your only choices for optical switches
propably sent from my amazon kindle 10th gen
