Author Topic: Cut an FR4 plate?  (Read 3547 times)
Offline Morbii
Cut an FR4 plate?
« on: Mon, 19 December 2022, 05:21:33 »
I have a solderable PCB that supports stepped caps, but the FR4 plate does not.  Is there a tool that can easily extend the hole for the caps lock to make it work?
Same question for: POM, Aluminum, Brass
Re: Cut an FR4 plate?
« Reply #1 on: Mon, 19 December 2022, 06:02:34 »
FR4 is fibreglass, and it is hazardous to inhale the dust. Be sure to wear goggles, gloves, a protective mask (not a medical one) and work in a special area that you don't live in. Collect all dust by doing it on top of paper or plastic that you fold together and get rid of. Then change clothes.
I also use a vacuum cleaner nozzle propped up to point directly at the item I'm working on. That way, the vacuum should suck up most of the dust.
As to tools: Dremel with cutting wheel or routing bits.
Offline Morbii
« Reply #2 on: Mon, 19 December 2022, 06:14:21 »
