Author Topic: [GB] Fragment R Artisan Tray - Ikeygai Designs 2/17 UPDATE  (Read 4623 times)
Offline Ikeygai Designs
« on: Tue, 20 December 2022, 22:35:24 »
294734-0
Ikeygai Fragment R Group Buy
26th December 2022 @ 12PM EST (CLOSED)
UPDATE: The GB has closed and the order has been placed with the manufacturer. Updates will be posted on our discord linked below. Will update this thread occasionally as well. Thank you all for your support!
The GB will last for two weeks starting on the 26th
The GB will happen over on our site - www.ikeygai.com
Estimated Fulfillment: Q1 2023
Tray Price: $120
Stand Price: $25
No Limit
Alexotos Video
The Fragment will be a series of trays starting with, Fragment R that uses magnets within the walls of the tray to connect two or more trays to form various shapes. The idea here is that we will offer different shapes and sizes in the future so that various trays can be used in conjunction with your existing trays to make any shape that you would like to. The magnets are placed in calculated positions so that each individual tray can be connected even in offset positions and not just in a linear placement.
Fragment R will be a 5 X 3 artisan tray with a mirror finish badge that can be put in any slot OR not used at all for an extra slot. There will be 3 magnets along the longer side and 2 magnets along the shorter side. The feet of the tray act as feet as well as stoppers to keep the magnets in place.
The lid is a case style lid that will give the tray more of a showcase feel. Instead of raising the walls of the tray and using a flat style lid that sits on top, we wanted to do something a little different. The lid will come with UV protection as standard.
Just like the lid we did not want to just make stand for the sake of making one. We wanted the stand to also fit the modular aspect we have kept throughout the tray design. So we went with this design that resembles a keycap, hence the name R5tand. It also works as a desk decoration  :)
Pictures
294736-1294740-2
294738-3294742-4
294744-5294746-6
Details:
Tech Specs:
  • Aluminum 6063 Grade
  • Anodized Finish (Sand Blasting TBD) & Powder Coating/E-coating
  • Neodymium Magnets x 10
  • Badge - Stainless Steel Mirror Finish
  • 15 x 1u Artisan Slots
  • Lid - Acrylic with UV Protection
  • Stand - Black Anodized Aluminum
Dimensions:
  • Tray Dimensions are 123mm x 75mm x 16mm
  • Keycap Slots are 20.4mm x 20.4mm, with a depth of 8mm
  • Badge Dimensions are 20.34mm x 20.34mm x 8.25mm
  • Lid Dimensions are 123mm x 75mm x 15mm; Clearance inside lid is 12mm
  • Stand Dimensions (Biggest dimensions only); Base 29.3mm x 29.3mm; Height 20.58mm; Angle - 17 Degrees
Colors:
  • Black, Red, Yellow and Green - Anodized Aluminum
  • White - Powder coat or E-coat (depending on volume/interest)
Contact (Come say hello!):
Discord - Ikeygai Designs
Instagram - @ikeygai_designs(https://www.instagram.com/ikeygai_designs)
Thank you all for support!
« Last Edit: Fri, 17 February 2023, 12:42:34 by Ikeygai Designs »
Re: [GB] Fragment R Artisan Tray - Ikeygai Designs
« Reply #1 on: Wed, 21 December 2022, 09:40:51 »
Approved :thumb:
