Author Topic: [IC] Phidias F-row less 1800 keyboard  (Read 56033 times)
Offline brunosan_.
« on: Fri, 23 December 2022, 19:48:13 »
Hello Geekhack, I designed Phidias about three years ago, and I have been perfecting it ever since. Now, it has reached its final form.
Pictures of the v2 and final prototype.
 Please consider filling out this form, it’ll be really helpful.
General Info
  • 7.5° typing angle
  • Tadpole aluminum plate & Polycarbonate pin mount plate
  • Front height ≈18mm
  • Capslock and NumLock indicator LEDs
  • Centered USB-C Unified C4 Daughterboard
  • Multi-Layout options
  • Solder PCB configurable with VIA
  • Widened JST channel for easier assembly
  • The top face on the blocker on both Stainless Steel versions is polished
  • The tadpole mount plate is compatible with GeonWork's tadpoles
  • 2.5M bottom-top screws
  • 2M for daughterboard and weights screws
GB details
From August 1-31 2024
Vendors:
Pricing:
Why this pricing?
I wanted to take a moment to explain the reasoning behind the price point. The hobby has evolved significantly since 2020-2022. In order to ensure the keyboard will be made, I had to lower the minimum required units.
Additionally, the manufacturers involved in this project are among the most reputable and high-quality in the hobby. You can expect to receive a flawless, perfectly finished unit.
Moreover, the keyboard kit includes everything you'll need for a fully functional keyboard. Unlike some other designers and stores that separate the price of the PCB, leading to higher overall costs, our kit provides the full value upfront.
Colorways
Clear PC top
  • Sandblasted Polycarbonate top
  • Silver aluminum anodized bottom
  • Sandblasted stainless steel weights
  • Sandblasted stainless steel blocker with the top face polished
  • Silver aluminum anodized plate (only if tadpole mount plate is chosen) or PC pin mount plate
  • Grey feets
Real Images
Cream Top
  • Powder coat cream top
  • Pantone 7532C aluminum anodized bottom
  • Sandblasted copper weights
  • Sandblasted copper blocker
  • Pantone 7532C aluminum anodized plate (only if tadpole mount plate is chosen) or PC pin mount plate
  • Black feets
Color chip Pantone 7532C for the bottom case
The colors shown in the renders are not exact representations of the actual manufactured color.
Black Top
  • Black anodized aluminum top
  • Graphite aluminum anodized bottom
  • Graphite aluminum anodized plate (only if tadpole mount plate is chosen) or PC pin mount plate
  • Black feets
Extras available
  • Phidias 1800 PCB
  • Custom Daughterboard + JST cable
  • Polycarbonate plate pin mount
  • Aluminum plate w/ tadpoles
What's Included?
  • Keyboard case (Materials and finishes depend on the configuration chosen)
  • PCB
  • Daughterboard
  • JST cable
  • Carrying case
  • Plate (Material depends on the configuration chosen)
  • Custom microfiber towel
  • Feets (Color depends on the configuration chosen)
  • 3 sets of Tadpoles of different hardness: 50a, 70a, and 90a. (Only if you choose tadpole mount plate)
Mounting system animation
Layout options
Q&A
Why is it called Phidias?
The number phi is present in almost every corner of the keyboard, It is also the primary source of inspiration that has gone into the making of this keyboard.
Why FRL?
After using full-size keyboards with the Function keys on them, I found out that I really didn’t use them that much, so it is more of a personal preference.
Do you have a sound test?
I don’t, however, the keyboard will be built in a stream with Alexotos, date is still TBD.
I want to thank Mr. quark for helping me out with the PCB design, this project wouldn’t be possible without him <3, and to all my friends on the KatanaKaji server.
Join the discord below or follow me on Instagram for more updates.
If you want to support this project, consider adding this signature to your profile.
Code: [Select]
[url=https://geekhack.org/index.php?topic=119210.0][img width=90 height=90]https://i.imgur.com/HLqvlpD.png[/img][/url]
« Last Edit: Sat, 27 July 2024, 15:01:40 by brunosan_. »
Offline brunosan_.
Re: [IC] Phidias F-row less 1800 keyboard
« Reply #1 on: Fri, 23 December 2022, 19:48:24 »
Reserved.
07/12/2024
Updated the IC with the final prototype pictures, mount configurations, and final colorways.
16/07/2024
Added pricing and renders for the different plate options.
« Last Edit: Tue, 16 July 2024, 14:54:19 by brunosan_. »
Offline Coquelox18
« Reply #2 on: Fri, 23 December 2022, 19:54:14 »
Reserved
Offline arq1999
« Reply #3 on: Fri, 23 December 2022, 20:24:55 »
Looks pretty good! Gotta love the red.
Question. Is the brass going to be clear coated?
Offline Robert.Lussier5
« Reply #4 on: Fri, 23 December 2022, 20:26:18 »
IC filled out! Must cop.
Austin R3 - Green // Austin R3 - Purple // Custom Acrylic Austin - Clear // Rekt1800 - Blue // Cypher r4 - Black // Boston - Sparkle Black // Balance - White // Glitch - Green // Shelby80 - Navy // Odin - Silver // Zoom65  Red // QK65 - Black // Link65 - Lilac
Offline linell
« Reply #5 on: Fri, 23 December 2022, 20:56:42 »
great design  ;D
bro this a **** set, just be thankful you even getting 1 base running fr
Offline vheissu
  • Pragmatic Geometrist
« Reply #6 on: Fri, 23 December 2022, 21:08:49 »
It has been a pleasure to see this project since its beginning, wishing you the best on this thing Bruno!  :thumb: :thumb:
Offline novelflyer
« Reply #7 on: Fri, 23 December 2022, 21:24:23 »
Happy to finally see the IC, congrats Bruno!  :thumb:
Offline Yuinth
« Reply #8 on: Sat, 24 December 2022, 00:33:07 »
It looks great!
Is the PCB going to be solder or HS?
Offline AshF
« Reply #9 on: Sat, 24 December 2022, 01:12:44 »
Gotta love an 1800
Sent from my ASUS_I003D using Tapatalk
Offline Pyroo
« Reply #10 on: Sat, 24 December 2022, 05:33:56 »
very nice
Bunny enthusiast
Offline brunosan_.
« Reply #11 on: Sat, 24 December 2022, 10:56:25 »
Appreciated! Yes, the materials that deteriorate fast such as brass and copper will be protected.
It looks great!
Thank you! The PCB will only be offered in the solder version, as I want to offer as many layout choices as possible.
The PCB support for other layouts will be modified depending on the results of the IC.
Offline QWER|key
« Reply #12 on: Sat, 24 December 2022, 12:07:28 »
It doesn't look it on the photos.
Offline kaifui gauo
« Reply #13 on: Sun, 25 December 2022, 21:39:28 »
Probably because of the pbt keycap, the pc plate with sw l + f, so the sound is not sharp, but this phone has a pretty good sound.
Offline HappyB0T
  • I'm a Piggie
« Reply #14 on: Tue, 27 December 2022, 22:14:58 »
Got excited that this had a cherry lip then realized it is variable. Pretty sure this is too 'exciting' for me. GLWIC
« Reply #15 on: Fri, 30 December 2022, 13:14:36 »
Will this be tadpole PCB mount or Plate mount?
Would love a plateless option.
Offline brunosan_.
« Reply #16 on: Sat, 31 December 2022, 11:14:31 »
The tadpoles are mounted on the plate so a plateless option wouldn't be possible, however, I can offer half-plate options for the group buy.
Offline KeyBros_
« Reply #17 on: Sat, 31 December 2022, 11:57:27 »
****ing good
Offline beejay
« Reply #18 on: Sun, 01 January 2023, 03:02:56 »
frl 1800 I'm in
« Reply #19 on: Mon, 02 January 2023, 12:34:28 »
That would be great!
Offline Abraham
« Reply #20 on: Tue, 03 January 2023, 02:37:17 »
Will there be other colors available :-*
Offline EffectMoon
« Reply #21 on: Tue, 03 January 2023, 10:35:31 »
I like the design
Offline LosTaquitos
  • Professional Procrastinator
    • Keebs.gg Profile
« Reply #22 on: Tue, 03 January 2023, 13:18:16 »
Looking good so far, I like the design! A hot-swappable PCB and sub-$300 price would make this an insta-buy for me. Any plans for more colors?
E-White & Brass Sonnet | Black Sesame V2 | GMK Civilizations
Offline mr_foggy
  • neue = nope
« Reply #23 on: Wed, 04 January 2023, 04:45:37 »
looks good. projected price?
Offline vodanhdaisu
« Reply #24 on: Mon, 30 January 2023, 03:35:16 »
Please make a Winkey version. I really appreciate
Offline vheissu
« Reply #25 on: Fri, 12 July 2024, 21:22:29 »
LOVED the IC revamp! Those photos and the general project looks crazy good, gl Bruno!
Offline HungHingDaiLo
  • 無間道
« Reply #26 on: Fri, 12 July 2024, 21:38:47 »
Interested!
IG: @rayhhdailo
Offline brunosan_.
« Reply #27 on: Sat, 13 July 2024, 11:19:38 »
Interested!
Thanks! I appreciate it
Offline lkkedward
« Reply #28 on: Sat, 13 July 2024, 11:20:58 »
Am I missing the price info?
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #29 on: Sat, 13 July 2024, 11:21:21 »
Please, can you show us the two versions (aluminum and PC) of the plate?
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Forvitni
« Reply #30 on: Mon, 15 July 2024, 19:34:20 »
What is the front height?
Offline brunosan_.
« Reply #31 on: Tue, 16 July 2024, 14:53:28 »
Sure, I added some renders of them bellow the Whats included section
Just updated the Price info per each vendor!
Offline brunosan_.
« Reply #32 on: Tue, 16 July 2024, 19:32:15 »
It's around 18 mm
Offline Kaptain Mike
  • discord: kaptainmike
« Reply #33 on: Sat, 27 July 2024, 08:13:18 »
Love what you've done here!
