Author Topic: quick question re making my own [tkl] case pieces  (Read 11276 times)
Offline simplycanada
« on: Thu, 29 December 2022, 14:55:50 »
I thought it seem more reasonable here (as beside this category labels itself "diy keyboards") than in the keyboard category but anyhow..
if I use http://builder.swillkb.com to make the template for the top layer to cut myself, I just wanted to check if cutting it exactly as defined by the given template would indeed provide a tiny clearance gap between the keycaps and the case itself?
thanks for letting me know/learn what to expect :-)
Re: quick question re making my own [tkl] case pieces
« Reply #1 on: Thu, 29 December 2022, 18:41:39 »
To make the size perfect you need to set the correct value for kerf - this compensates for the thickness of your cutter.
