Author Topic: gateron switches on kebo.store webshop?  (Read 3649 times)
Offline simplycanada
« on: Fri, 30 December 2022, 09:16:03 »
wondering if its just me or are these two sources not actually matching up with each others as far as colour coding seem to go?
https://kebo.store/products/gateron-silent-switches?variant=41127006830746
versus
https://www.gateron.co/products/gateron-silent-switch-set
Offline Sup
Re: gateron switches on kebo.store webshop?
« Reply #1 on: Fri, 30 December 2022, 20:59:38 »
I don't get it. You mean that the colors are off color from each other? In anyhow they are the same switches.
current
Coming soon
Offline qeebored
« Reply #2 on: Sat, 31 December 2022, 05:06:53 »
I think he means that the described actuation force and the color coding of it are different between the sources:
Switchkebo.storegateron.co
Silent Yellow35 g50 ± 15 g
Silent Red45 g45 ± 15 g
Silent Black50 g60 ± 15 g
Silent Clear50 g -
Silent White-38 ± 15 g
Silent Brown45 g55 ± 15 g
A yellow switch is a light switch at Kebo, but a medium switch at Gateron, and a White switch at Gateron is light, but the similar-looking clear at Kebo is a medium switch. It is interesting to note that the differences between Kebo and Gateron are within the interval that Gateron describes (± 15 gf)
« Reply #3 on: Sat, 31 December 2022, 05:44:40 »
qeebored hm I had not quite realized that it was still technically correct that way when you look at that now
thanks btw
