Author Topic: [GB] 239$ Dolphins75 - 4th to 17th January 2023  (Read 5409 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Mon, 02 January 2023, 21:58:28 »
Hello keyboard friends, this is Velocifire. The GB of our elegant 75% custom mechanical keyboard Dolphins75 is live now! Thank you guys so much for following and supporting this project!  :)
Price:
239USD
Vendor
Worldwide: Velocifire
GB Time
4th-17th January 2023
Lead Time
Late February 2023
Limit Units
200
Welcome to join our Discord for more discussion!
Welcome to visit the Product Page for more details.
Introduction
Just like the name of the keyboard, its design inspiration comes from the streamlined shape of the dolphin's forehead bulge and the gradual shrinking shape of the tail.
The special curve design makes the keyboard look simple and elegant.
Besides, it provides you the smooth silky touching feel with better case craft, feel like touching the dolphin skin.
As lovely dolphins are friends of human beings and always accompany us at sea, we want to make Dolphins75 more user-friendly in daily life, just like the dolphin accompany you all the time.
Prototype
Gray
White
Pink
Wine
Specifications
Case color: E-white, Gray, Pink, Pink-White, Wine Red, Purple, Purple-White
Plate material: PC, POM, Alu, Brass, FR4
Case material: Full CNC Aluminum 6063
Full built weight: about 2.4kg
Typing angle:7°
Front Height: 20mm
Size: 327.8 × 150.1 × 18mm
Render
Youtube Videos
Pudding
TofuTypes
Gasket-foam mount
In order to improve the typing consistency for all keys, we use the gasket - foam instead of gasket to keep every single key the same typing feel.
What's more, it makes the build process simpler and easier by conbining the gaskets and foam.
PCB Specification
1.2mm thick
Single key flex-cut design
Hotswap PCB support ANSI layout ;Solder PCB support ISO & ANSI layout
QMK & VIA support
Thank you for your attention!
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Re: [GB] 239$ Dolphins75 - 4th to 17th January 2023
« Reply #1 on: Tue, 03 January 2023, 11:09:03 »
Approved :thumb:
Offline lowsmaxduncan12
« Reply #2 on: Tue, 03 January 2023, 21:24:15 »
Nice! simple and well priced.
