Author Topic: Epomaker TH80 gateron pro black  (Read 10634 times)
Offline skeucore
    • My website
« on: Wed, 04 January 2023, 08:01:21 »
Review of the Epomaker TH80
Sound
Very nice and thocky
Feel
Easy-to-press keys.
Keycaps are high quality.
Case is also good quality.
The keyboard is pretty heavy (1kg)
Stabilizers
The stabs are a bit rattly. Not much though.
The space bar is the rattliest.
Functions
High Quality red aluminium knob.
All keys programmable using Epomaker Driver.
Extra keycaps for mac and windows.
Bonus keycaps with icons.
USB-C Charging
Connect to computer using cable, Bluetooth or USB receiver
RGB lights with patterns (Wave, rainbow, etc...) or single color
RGB light brightness and speed adjustment
Keycaps
PBT Keycaps in MDA Profile & Dye-sub Technique
  • [/size]Layout[/color]
    [/size]75%[/color]
    [/size]Choose between ANSI and ISO layout (I have the ANSI layout)[/color]
    [/size][/color]
    Switches
    Gateron Pro Black switches
    Factory-Lubed
    Spare switches
    [/size]3 pin or 5 pin switches compatible
    [/size]Hot-swappable
    [/size]South-Facing LEDs
    [/size]
    [/size]Battery
    [/size]3800mAh
    Comes with..
    braided USB-C to USB-A cable
    User manual
    Keycap and switch removal tool
    extra switches
    extra keycaps
    Cost
    Starts at 99.99$ (Depends on your model)
    Would I recommend it?
    Yes, Its a great value
    Website:
    https://epomaker.com/products/epomaker-th80?variant=39613161013321
