Author Topic: [GB]Heracles80  (Read 4377 times)
Offline CHAOSERA
    • official website of chaosera
[GB]Heracles80
« on: Sun, 15 January 2023, 22:54:38 »
Hello everyone, we are CHAOSERA!
After half a year, Heracles80 is finally GB today. As a kit weighing more than 4kg, it has been controversial since the beginning of IC.
But we finally made it under the big pressure. One, there are always people who like this kit supporting us. Second, we ourselves really like the heaviness that this weight provides and the stability it brings to the sound of the keys. All this made us stick to it. GB is coming soon, we feel a little excited.
295556-0
295558-1
In addition to the weight, the surface technology of Hercules80 is also more elegant electrostatic powder spraying. Although spraying glitter powder is not a very special process for the custom keyboard at present. But for our keyboard, the average thickness of the powder exceeds 20 μm, and it feels dry to the touch, which is a relatively representative powder-sprayed surface.
295560-2295562-3
If you know and love powder spraying. There is a big chances that you'll love it. Unfortunately, maybe our shooting skills are not enough, so the texture presented in the photos is far inferior to the real thing. I believe that the physical performance will surprise everyone.
In terms of embellishment, we have also put more thought into it. Three different processes are used on the front. Anodes and powder spraying are used to enhance the texture, and high-gloss lines are added to the inner and outer frames of the panel, which enhances the overall noble temperament.
295564-4
295566-5
The back will be relatively complicated, we use mirror PVD+titanium anode. It can be regarded as a show of craftsmanship. The titanium finish is the main delay of this keyboard. We don't want the increase of craftsmanship to stop at simple stacking, but the more effective sublimation of the theme is the meaning. Use a set of patterns that fit the theme. It just like slowly unfold it in front of everyone like a parchment to tell you the myth of a long time ago.
295568-6
295570-7
295572-8
I won’t go into too much detail, you can basically see it in our previous posts, and I will release the link to the previous post below:
Structural Analysis IC:
[IC] Heracles 80 TKL/Keyboard Image Update (geekhack.org)
First, Kit information
Layout: 80%TKL(87 keys)
Keyboard structure: Gasket Mount
Keyboard angle: 7 degrees
PCB: 1.2mm single key slotted immersion gold PCB (support via editing)
Keyboard material: 6063 aluminum (counterweight 316 stainless steel + TA2 titanium alloy)
Keyboard front height: 17.3mm
There are three colors in total:
Starry Night: The dark powder-sprayed surface looks like twinkling stars in the dark under the blessing of glitter powder. So we named him Starry Night.
295574-9
295576-10
Holy Light: warm ivory white with desecrated gold panels. Coupled with the embellishment of the high-gloss lines on the panel, it looks like a noble goddess and is very desirable. These characteristics lead us to name it Holy Light.
295578-11
295580-12
Black Knight: The upper and lower covers are pure black. Black panels with silver highlights, plus black PVD. At the beginning of the project, we always wanted to create a special color scheme, tried a lot, and finally settled on the black warrior. After all, which one can refuse a handsome Black Knight?
295582-13
295584-14
Second, Contents of the kit
Keyboard case x1
Poron Case Foam/ Without hot-swap cut  1mm x2
Poron Case Foam/With hot-swap cut  1mm   x1
Poron  Case Foam/With hot-swap cut 2mm x1
Sponge Case Foam   / With hop-swap cut  3mm x1
Sponge Case Foam   / With hot-swap cut 4mm x1
CR Case Foam/Without hot-swap cut
CR Case Foam/With hot-swap cut 2mm   x1
CR Case Foam/With hot-swap cut 3mm x1
CR Case Foam/Without hot-swap cut 3mm x1
PC Plate x1
Flat head screw x12
Countersunk head screws x12
Hex Socket Cap Screw x19
Foot pad   (a pair of long and short)
PCB, Daughterboard, Wire x1
Gaskets x12
Copper Pillar x12
PCB Foam
IXPESwitch Pad x1
Stabilizer pad x1
Nemoan Lion Head Artisan Keycap
295586-15
295588-16
Third, a gadget
Anyone who knows us well knows that we like to do joy things, and this time was no exception.
We have designed a very interesting addition, a pair of fists that can be assembled on either side of the counterweight - the Hercules Fist.
Made of pure copper, the whole process is CNC processed, the process is time-consuming, so there are only 10 sets, and those who are interested can buy more.
295590-17
295592-18
295594-19
Forth, How to join Heracles GB
In order to allow you to get better after-sales service and lower shipping costs, users in the following regions can purchase Heracles80 from our venders
EU Mykeyboard :https://mykeyboard.eu/catalogue/category/group-buys/keyboards/heracles-80-tkl-keyboard-kit_840/
UK Mechboards :https://mechboards.co.uk/products/chaosera-heracles-80-keyboard-group-buy
Canada Ashkeebs : https://www.ashkeebs.com/product/heracles80-keyboard/
US Divinikey :https://divinikey.com/
Korea Monstargear : https://www.monstargear.co.kr/160/?idx=794
Vietnam Thekeebs : https://thekeebs.store/products/heracles-80-keyboard-kit
Taiwan, China : https://discord.gg/expensivekeyboard
Except for the United States, the above regions will start group buying at 23:00 on January 15th, Beijing time.
The time for Divinikey to open GB is to be determined.
In addition, CHAOSERA's official website will prepare a small amount of inventory for customers in other regions to purchase.
Estimated delivery time: April 15th
Link to CHAOSERA official website: https://www.chaosera-sell.com/
Fifth, QC standard:
All artwork cannot be guaranteed to be completely flawless. The so-called flawless is based on the QC standard, the following is our quality management standard. If you are a perfectionist, please carefully read the following standards and purchase carefully.
Determination of PVD and highlight delineation defects
The front is 30 cm away from the naked eye, without deliberate lighting, ensuring flawless PVD and highlights
Spay Powder Defect Judgment
One or more pinholes with a diameter greater than 0.3mm in the main visual area are defective products
In the main visual area, there are more than 3 pinholes with a diameter of less than 0.3mm in one area (within 10mm), which is a defective product
In the main visual area, the accumulation with a diameter greater than 0.5mm is a defective product
Sixth, Price
Uniform price: $375
(Black Knight: $429)
Supplement:
Hercules Fist $59
Aluminum positioning plate $15
POM positioning board $15
FR4 Positioning Plate $15
Finally, everyone is welcome to join the group to guide the work: https://discord.gg/eYBJpC8Zbf
« Last Edit: Thu, 19 January 2023, 22:00:59 by CHAOSERA »
Re: [GB]Heracles80
« Reply #1 on: Thu, 19 January 2023, 22:07:35 »
Approved :thumb:
Offline CHAOSERA
Re: [GB]Heracles80
« Reply #2 on: Fri, 20 January 2023, 00:41:40 »
Approved :thumb:
Thank you for your review
  chaosera lab
Offline maximm
Re: [GB]Heracles80
« Reply #3 on: Fri, 20 January 2023, 11:41:54 »
Does it have iso support?
