Author Topic: [IC]Zoom65EE V2 is Live-New case Colorway,Per-key RGB PCB,Seamless Side Profile  (Read 5107 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
Hi Everyone!
We are glad to share with you that Zoom65 EE V2 is live from Meletrix.com and most vendors :)
Zoom65 EE V2 collection page
Zoom65 EE V2 Photo Gallery
Zoom65 EE V2 Configurator
What’s New with Zoom65 EE V2
1.New case colors: Ivory Cream, Teal, Cyber Yellow, GT Silver
2.Seamless side profile
3.PCB with daughterboard
4.PCB with per-key RGB
5.Glass/PVD backplate design
6.Easier-to-install sleeve gaskets
7.New Stabilizers (WS Stabs V3)
Zoom65 EE V2 Reviews/Live streams
* starfirepenguin
* Alexotos
* Simulator Tech
* ThockyDocKey
* CaviteTech // Johan Villanueva
* Rx003
* :3ildcat
More will be updated before and during GB
Next - Level Customization
126 Default combinations
* 14 case and backplate combos (the same color)
* 9 knob&weight combos (the same color)
You can choose up to 126 color ways as your default keyboard kit.
19404 DIY combinations
* 14 case colors
* 14 bottom plate colors
* 11External weights
From add-ons, you can choose up to 19404 combinations to DIY your dream board.
Multi-Layout
ANSI, ISO, split spacebars, step caps lock, right shift, backspace
Bluetooth 5.0 PCB that supports VIA, battery included.
This is the default PCB of all Zoom65 Essential Edition. You customize it through VIA.
This PCB can be used in wired or wireless mode.
There will be a battery included with every Zoom65 Essential Edition. You do not need to source one yourself.
Kit Contents
Aluminum top & bottom case of buyer's choice
Aluminum / SS external weight of buyer's choice
Aluminum/brass rotary knob matching the external weight.
Hot-swap, multi-layout Bluetooth /VIA PCB with per-key RGB
Polycarbonate plate
Set of WS Stabilizers V3
2300 mAh Li-ion battery
Coiled USB-C cable
Full foam kit
Gaskets
Screws and other installation tools and accessories
Faux suede storage case
Specifications
Gasket mount design
6.5°Typing angle
20mm front height
Pricing
Zoom65 EE V2 pricing image link: https://imgur.com/a/8MU0IX7
GB Schedule
GB Time: Jan. 26, 2023 - Feb 13, 2023
There will be a soft limit according to production materials we prepared, GB may be closed earlier if quantity reaches to the limit earlier.
Delivery Time: early April, 2023, start sending to Meletrix direct customers or vendors
Please join Meletrix Discord for more frequent updates.
« Last Edit: Sat, 28 January 2023, 11:27:39 by Ckeeb »
Offline maoam
Is it just me, or does the front height look way more than 20mm? (At least in some of the prototype pictures)
It's because aspect ratio is not maintained on the images in the post. Looks normal when viewed in actual size.
