Author Topic: [GB] Fox Lab Sunset 80/TKL  (Read 5807 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Thu, 19 January 2023, 23:45:10 »
Sunset 80
Designed by Fox Lab
Index
- Intro
- Product Reviews
- Gallery
- Colorways
- Groupbuy Info
- Kit Options
- Add-ons
- Specification
- What's Included
- Socials
Intro
Hello everyone,
This is ClickClack. We are ready to kick off groupbuy of Fox Lab Sunset 80!
Sunset 80 is a TKL with a unique Damascus weight and a sunset-shaped light feature on the front. Structure-wise, Sunset 80 can be build in regular gasket mount or plateless.
To learn more about Sunset's design, please refer to Interest Check Post.
Product Build and Review Videos
▲ alexotos
▲ LightningXI (using 1.6mm PCB)
▲ LightningXI (using 1.2mm PCB)
▲ TaehaType
Looking for more pictures?
Colorways
▲ Obsidian Black: Mirror PVD SS Main Weight and Navy Damascus weight
▲ Moonlight Silver: Mirror PVD SS Main Weight and Babyblue Damascus weight
▲ Bordeaux Red: Mirror PVD SS Main Weight and Silver Damascus weight
Groupbuy Info
Join GB here
Pricing: $485
Groupbuy Start Time: 01/20/2023 12:00 EST
Groupbuy End Time: 01/25/2023 23:59 EST
Estimated Fulfillment Time: Q2 2023
Sale Format
▶ FCFS, 180 units limit for each colorway and each color will be available for 2 days/until limit hit
▶ Colorway sale schedule: 01/20 - 01/21: Obsidian Black, 01/22 - 01/23: Moonlight Silver, 01/24-01/25: Bordeaux Red
Kit Options
You may choose PCB in your kit:
▶ Soldered
▶ Hotswap
You may choose from following layout for your kit:
▶ WKL F13
▶ WK F13
Add-ons / Extras
▶ Hotswap PCB: $60
   ╚ 1 x 1.6mm Hotswap PCB
   ╚ 1 x IXPE Foam for PCB
   ╚ 1 x Polycarbonate Plate
   ╚ 1 x Poron Plate Foam
▶ Soldered PCB: $60
   ╚ 1 x 1.6mm Soldered PCB
   ╚ 1 x Auxiliary Solder Plate
Specification
► Materials: 6063 aluminum, stainless steel, Damascus titanium
► Layout: 80% Tsangan with F13 / 80% TKL with WKL blockers and F13
► Mount: Gasket Mount
► Typing angle: 7.5°
► Front height: 18.5mm
What's Included
► Top and bottom case
► Stainless steel main weight
► Stainless steel sidebar
► Titanium Damascus Sunset weight
► Titanium Damascus light piece
► Acrylic light diffuser
► 1.6mm PCB (We listened to community feedback and now PCBs are all updated to 1.6mm)
► Daughterboard and connector
► RGB light feature daughterboard and connector
► Gaskets
► POM alignment pins
► 0.5mm PORON Case foam
► Stabilizer shims
► IXPE PCB sheet
► Rubber feet
► Weight protection film
► Optional solder PCB
► Auxiliary solder plate (standard with soldered PCB)
► Polycarbonate plate (standard with hotswap PCB)
► PORON plate foam (standard with hotswap PCB)
► Screws
Stay tuned with us
Join Fox Lab's Discord:
Join ClickClack’s Discord for latest update, discussion, questions:
Follow ClickClack's IG for other new projects:
« Last Edit: Fri, 20 January 2023, 09:10:12 by ClickClack.io »
