Author Topic: SMK inverse cross mount Cyan ???  (Read 4367 times)
Offline Tor221
« on: Fri, 03 February 2023, 07:05:43 »
I found this smk switch in a unkonw keyboard(maybe a computer host).
Looks like blue.But when I search it on the deskthority the color is completely different, close to  cyan?
even not tactile, it is liner!!!!!
Is it be found before? and name?
« Last Edit: Fri, 03 February 2023, 07:12:43 by Tor221 »
Offline Maledicted
Re: SMK inverse cross mount Cyan ???
« Reply #1 on: Fri, 03 February 2023, 11:59:22 »
I mean, it is definitely SMK inverse cross mount. Those sliders look a lot like the common Alps mount clickies in color. You should make an account on Deskthority and make a thread about it over there. You're most likely to encounter people who may have ever seen that variant before there. The wiki isn't necessarily always rigorously updated.
It seems like SMK went nuts on the color variations with the cross mounts, in particular.
