Author Topic: [IC] Rex60 Lite - Default/Tsangan 60% PCB - $19  (Read 6281 times)
Offline hlord2000
« on: Wed, 08 February 2023, 20:59:31 »
The Rex60 Lite
IC Survey | Discord
Layouts
296252-0
Front
296248-1
Back
296250-2
The Rex60 Lite is a GH60 compatible PCB with default/tsangan layout support.
Supported cases include:
  • GH60 tray mount
  • CannonKeys Bakeneko60
  • Tofu60
  • And many other GH60 compatible cases!
Features
  • Default 60%/Tsangan support
  • JST + USB-C support - A new USB-C connector, with fine-pitched through hole leads, can be hand-soldered
  • Bakeneko/gummy-mount cutouts
  • Vial support
  • $19 + shipping
All Rex60 Lites will include a USB-C port. USB-C soldering is only $5!
Add a Unified Daughterboard + JST for $5!
IC Survey | Discord
« Last Edit: Wed, 08 February 2023, 21:15:49 by hlord2000 »
Offline hlord2000
Re: [IC] Rex60 Lite - Default/Tsangan 60% PCB - $19
« Reply #1 on: Wed, 08 February 2023, 21:00:31 »
EDIT 2/9/23: Added indicator LED spots for CapsLock!
« Last Edit: Thu, 09 February 2023, 19:47:41 by hlord2000 »
Offline Pach
« Reply #2 on: Wed, 08 February 2023, 21:24:59 »
I Love Lord Board
Offline xxx
  • phoenix (le epic keyboarder)
    • mkh
« Reply #3 on: Thu, 09 February 2023, 00:58:44 »
ok
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #4 on: Thu, 09 February 2023, 06:46:31 »
No ISO support in a solderable PCB? Come on guy...  :rolleyes:
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline stewfayew
« Reply #5 on: Thu, 09 February 2023, 08:58:32 »
This appears to be bakeneko v3 compatible  :)
Offline pixelpusher
« Reply #6 on: Thu, 09 February 2023, 09:41:04 »
Where is it going to be shipped from?  $19 is outstanding, but the “+ shipping” can get pricey sometimes
Offline hlord2000
« Reply #7 on: Thu, 09 February 2023, 16:55:55 »
Will be shipped from the southeast US.  Thanks for the question! Shipping is typically $5-15 in the US depending on package weight.
Offline RzrRaptor
« Reply #8 on: Thu, 09 February 2023, 18:25:23 »
Would this pcb also work with the tofu60 2.0?
Offline hlord2000
« Reply #9 on: Thu, 09 February 2023, 19:46:29 »
Yes it should. Thank you for the question!
Offline hlord2000
« Reply #10 on: Thu, 16 February 2023, 19:32:55 »
Prototypes have arrived!
I added split right shift and LEDs for capslock. Looking really promising. Moving to GB soon.  :thumb:
296551-0
296553-1
296555-2
Offline aicyborg
« Reply #11 on: Thu, 16 February 2023, 20:16:34 »
Please consider ISO support. Unless there is an interference issue or some other reason, it makes sense that this be as flexible as possible.
