Author Topic: [IC] Alyssia - A thin bezel, dual mount Alice style keyboard - Updates 10/25/23  (Read 33329 times)
Offline Patty
  • do u like my cat yes or no
ALYSSIA
Interest Check Form
https://forms.gle/yTjhn8gMeKgrjX7P7
Interest Check Form 2
https://forms.gle/dMaLfJygH7tRD9yX9
Interest Check Form 3
size=10pt]https://forms.gle/x8HV8jicN2gQe4Ta7[/size]
Final Interest Check Form
https://forms.gle/z8xjMY3uy6H5J1Pz5
Discord
https://discord.gg/PrPU83efVe
Introduction
I’ve been in the hobby for a few years now and have attempted on and off to design my own board, specifically an Alice layout.
I’ve tried several Alice boards, as well as other boards and settled on my own personal preferences in terms of design.
Hence, the Alyssia, my first completed design, incorporates thin bezels, a 4 degree board angle and a fancy outer piece to look at.
Technical Details
Board front height: 18.5mm (measured at chin)
EKH: 22.64mm/23.64mm with feet (measured at right alt)
Materials: aluminum 6063 (top, bottom), copper (inner weight, coated), polycarbonate (light diffuser, DB wire cover)
The outer piece will be available in alu 6063, coated copper and raw SS304
Weight: ~3.1lbs built (1406.14g), 2.45lbs unbuilt (1111.301g) with the alu outer piece
Mounting Style: O-Ring tab gasket mount, top mount
Screws: 6x M2x12mm button torx (for body), 5x M2x4mm countersunk torx (for light diffuser,db wire cover),
4x M3x4mm countersunk torx (for inner weight and outer piece), 8x M2x4mm button torx (for top mount)
Manufacturer: DDS
Standard Alice layout compatible with top-mounted USB-C PCBs, some USB-C daughterboard Alice PCBs
Mounting Explanation
The Alyssia uses 8 o-rings that fit around 8 tabs on the plate
The o-rings are tightly wrapped around the hooks of the plate tabs, with a bit of the gasket left out on the outer edge to ensure the plate doesn’t touch the board directly
The o-rings are lightly compressed by the top and bottom piece, creating a firm typing experience that can be softened depending on the plate/o-rings used
This mounting method also helps with alignment of the top and bottom pieces of the board
O-Ring info: 22mm OD x 18mm ID x 2mm thickness, 70 duro, NBR material
I've added top mounting capabilities to the board, it's not the universal Alice mounting points as the board is too small to use a universal Alice plate,
it'll use M2 screws, the plate will accommodate both gasket mounting and top mounting
Pictures of the Prototypes
Prototype 3
Prototype 2
Prototype 1
Renders
Sound Tests
This is the third prototype
Lightning Sound Test (Alu half, JWK Cotton Candy, Tab O-Ring mount)
Nainaigogo Sound Test 1 (PC Plate, Stock Mode Obscuras, Tab O-Ring mount)
Nainaigogo Sound Test 2 (PC Plate, Stock Punkshoo Runners, Tab O-Ring mount)
This is the second prototype
Alexotos VOD
Built with broken-in MX blacks on a PC plate, GMK WoB
Color Options, Plates and PCBs
Body: Black, Silver, Light Purple, Dark Red, Pink
Outer Piece: Anodized Alu (matched to the body), Clear-Coated Copper, Raw SS304
Due to a manufacturer change, the outer piece can no longer be offered in PVD options
Included plate options will be PC and Aluminum, Alu Half plates can be purchased as an add-on
You can choose between no PCB, the Sneakbox Alice Clone PCB, or the Sneakbox M5 PCBs (either hotswap or solder)
Sale Information
Units: 100 with the possibility of increasing if there is more demand
Pricing (@50 MOQ):
With PCB
Alyssia Standard: $430USD + shipping/tax
Alyssia Copper Upgrade: $480USD + shipping/tax
Alyssia Raw SS Upgrade: $520USD + shipping/tax
NO PCB
Alyssia Standard: $390USD + shipping/tax
Alyssia Copper Upgrade: $440USD + shipping/tax
Alyssia Raw SS Upgrade: $480USD + shipping/tax
Purchase-able Extras:
Outer Pieces (anodized alu, copper and raw SS)
PCBs offered by Sneakbox
Alu plate, pc plate, alu half plate
What's included:
Alyssia Body, Outer Piece, DB Wire Cover, Light Blocker, Inner Weight
PC or Aluminum Plate
PCB or no PCB
Case screws, top mount screws
O-rings
Feet
Carrying Case
Microfiber cloth
DB M3 standoffs (for the M5 PCBs)
Torx screwdrivers (T6, T10)
4.5mm Hex Nut Driver (to help screw/unscrew standoffs)
Vendors and GB Date
Worldwide: Sneabox Design (Woohoo!)
GB Date is currently set for November 19th (11/19/2023)
Prototype Showcase and Streams
Xinxinwong and StarfirePenguin will be showcasing the 5th prototype in November/December!
Alexotos will be building a special Alyssia unit sometime in November/December as well!
Lightning showcased and streamed a build of the 3rd prototype!
You can watch the VOD here: https://www.youtube.com/watch?v=eqzDwSM2MbM
Nainaigogo showcased and streamed a build of the 3rd prototype!
You can watch the VOD here: https://www.twitch.tv/nainaigogo
Alexotos showcased a build of the 2nd prototype!
You can view the VOD here https://www.youtube.com/watch?v=MSx6JCNESB8
Changelog
Prototype 1:
Initial design, had a sandblasted stainless steel outer piece, no external fillets/chamfers,
used 4 M1.4 screws to screw the case together, uniform floor below PCB, slightly larger internal weight, less aggressive exaggerated seam
Prototype 2:
Changed outer piece to PVD aluminum/increased size of outer piece, added more external fillets and chamfers,
uses 6 M1.6 screws to screw the case together, floor below PCB has been raised around modifiers and numbers, internal weight shaped around alphas,
more aggressive exaggerated seam, changed design of case alignment tabs, added more material to the top case
Prototype 3:
Reduced feet height by 0.5mm
Lowered height of USB-C opening by 0.3mm
Top mount added
Alignment pins are larger
Alignment post added to outer piece
Top piece now has a uniform fillet all around rather than a larger fillet at the front edge with smaller fillets on the other edges
Ledge in bottom piece has a more stepped design
Inner weight thickness increased to 2.5mm, .5mm alpha cuts added
Plate tabs adjusted to better fit o-rings
Changed screws to M2
Prototype 4:
Added compatibility for Sneakbox M5 PCB, added compatibility for fly daughterboard
Added a wire channel for daughterboard wires, designed a cover for the hole
Changed miscellaneous fillets to chamfers
Removed two alignment pins that were unnecessary
Prototype 5:
Cleaned up minor issues with Proto 4 daughterboard implementation
Comments
I plan on releasing these files after the GB:
Plate file
Light diffuser file
Internal weight file
DB Wire Cover file
Shape of gaskets file (to allow people to get custom cut foam gaskets if they prefer)
As there are no widely available Alice PCBs that use a daughterboard I opted to design the board around top-mounted USB-C Alice PCBs,
but if there ever comes a time when Alice PCBs that use daughterboards do become widely available
I will redesign the outer piece to fit them if possible and release the file
I've decided to add compatibility with Sneakbox's M5 PCB (which has it's own db design) and the fly daughterboard,
although there are some limitations when using the fly daughterboard
1. PCB shape needs to have a small cutout at the top like the M5 PCB
(meaning the Dolice PCB isn't gonna work cause it has the same shape as original Alice PCBs)
2. If the PCB uses a molex connector it should be good, if it uses JST you'll have to either remove the inner weight
or the JST has to be in the same spot as the M5 PCB
Special Thanks To
Yuktsi for the TGR Alice, for open sourcing the layout, and for my eventual love of typing on Alice keyboards
All the Alice designers out there, I love all of your boards, they are all beautiful
heyimpanda for being a great friend both in and outside of this hobby and for building the second prototype/creating the sound test
Alexotos for agreeing to showcase the 2nd prototype, love you Alex!
Nainaigogo for agreeing to showcase the 3rd prototype, YOU'RE AMAZING NAINAI!
Lightning for agreeing to showcase the 3rd prototype, THANK YOU SO MUCH LIGHTNING I'M A HUGE FAN
Muji from Sneakbox Design for being an awesome dude and for supporting the project, thank you so much Muji!
The community for being awesome, for instilling in me my love of keyboards and design, and for creating amazing stuff that continues to inspire me
To Do
Get IC 1 results
Get IC 2 results
Get IC 3 results
Order proto 3
Send proto 3 out to streamers/reviewers
Do more renders and get better ones
Order proto 4
Get a vendor onboard
Finalize pricing and options
Begin GB!
Once again, please consider filling out IC 3! https://forms.gle/cexUrgT3Hv2bEGqe8
« Last Edit: Wed, 25 October 2023, 18:35:11 by Patty »
Offline Patty
Re: [IC] Alyssia - A thin bezel, gasket mounted Alice style keyboard
« Reply #1 on: Mon, 13 February 2023, 15:46:37 »
Reserved
Update 1 - 3/13/2023
The IC post has been updated, I've made a number of changes to the design (mostly internal)
You can read more about it here or re-read the IC for more info on the updates/changes
Update 2
I've added top mounting capabilities to the board, it's not the universal alice mounting points as the board is too small to use a universal alice plate and the gasket mounting points are in the way anyway, it'll use M1.6 screws, the plate will accommodate both gasket mounting and top mounting
I've made a change to the alignment pins, they're larger now
I've added alignment posts to the outer piece that should make it easier and more accurate to assemble
The top originally had a larger rounded edge at the front which unfortunately was barely visible on the prototype, I've decided to remove it and have a uniform fillet all around
The ledge in the bottom piece internal at the chin has been changed to a more stepped design, should be easier and cleaner to machine
Inner weight thickness has been increased slightly to 2.5mm from 2mm, alpha cuts have been added and are .5mm deep
I've cleaned up a good amount of small details and geometry in the models for all the parts, added more fillets, chamfers and visual niceties
The plate tabs were a bit too tight on the alu plates, causing the orings to not grip the tab all around as nicely, I've made a small change that hopefully will alleviate this while not affecting plastic plates
My manu informed me that the PVD finish on the outer piece is the most expensive aspect of the board, I'm considering offering a regular ano finish instead as the base option with the PVD as an upgrade as a way to lower the base price, to keep variants lower I've also decided to run only 3 colors, either silver will be kept or replaced based on the responses to interest check 2
Renders have been updated to reflect changes
There are enough changes for me to warrant getting a 3rd prototype, it'll be ordered in the color selected in interest check 2 after 1 week of responses unless silver wins out, in that case I'll order the black variant
Based on interest check 1, the gb will be running with PC and alu as the plate options, alu plates will color match the outer piece, the light blocker will be kept
Vendors are still TBD
Update 3
Finalized color options, vendors are TBA, pricing is certain to be less than 400USD, changed out the renders, changed the design in small ways (M2 screws now)
Update 4
Re-finalized color options, no more PVD outer piece due to manufacturer change, vendor onboard and GB date set
« Last Edit: Wed, 25 October 2023, 17:47:05 by Patty »
Offline Mandabanker007
« Reply #2 on: Tue, 14 February 2023, 20:07:13 »
I’m listening
Offline lunr
« Reply #3 on: Fri, 17 February 2023, 12:48:50 »
interested as well. hope it goes through.
Offline zhol
  • zhol
« Reply #4 on: Sat, 18 February 2023, 03:09:07 »
the price is pushing my limits a little, but this thing looks rad. glwic, attention to typing angle and height measurements is super appreciated
maybe weight could accommodate fly daughterboard to keep it forwards-compatible with some future alice pcb that would work with it, but i'm just spitballing there
i'm zhol
Offline tim981045
« Reply #5 on: Mon, 13 March 2023, 09:18:06 »
It look beautiful , I want get one
Offline Patty
« Reply #6 on: Mon, 13 March 2023, 13:01:05 »
Hey everyone! Thanks for the support so far and all of the responses to IC Form 1, I really appreciate the feedback
I've made several updates to the design/IC information as well as posted IC Form 2, IC Form 1 is now closed
You can either read more about the updates in the reserved comment or re-read the IC as a whole
I've reached out to Alexotos and he has agreed to showcase the board! The stream is tentatively set for 3/14/2023 but I will update the post if that changes
I've also created a Discord channel for anyone who'd like to join and receive updates there! https://discord.gg/PrPU83efVe
Once again, thanks to everyone who responded to the first IC! I'm honestly so excited to watch Alexotos build the 2nd prototype lol I've been watching him stream since I started the hobby and it's kinda just cool to see him building something I've designed, never thought I would get to this point
« Last Edit: Mon, 13 March 2023, 13:13:57 by Patty »
Offline Patty
« Reply #7 on: Mon, 13 March 2023, 13:09:39 »
Accommodating the fly daughterboard would be something I'd love to consider, but honestly adjusting the outer piece would depend on the overall design of an Alice pcb using a daughterboard, whether it'll look something like Sneakbox's M5 Alice pcb or just Mechlovin's Alice pcb with a db connector on it or something else entirely, regardless I'll edit the outer piece to accommodate whichever implementation becomes the most available if possible
Offline farlig
  • * St. Jude Supporter
Love the look of this, definitely gonna be keeping an eye out for updates.
Offline Patty
Some updates, but more importantly Nainai is streaming the 3rd proto today at 7:30PM EST! Please tune in and support her, thank you!
Offline streamline
    • saevus
So niceeeee
Offline Patty
hey everyone! made some changes to the board to include daughterboards, renders are also updated to show all available colorways from a top down perspective, still working on creating more renders
Lightning will also be streaming a build of the 3rd prototype today at 4:30PM EST! Please join the stream and support him!
Offline LightningXI
  • PPD
    • ArtisanMacro
Here some pics of the proto!
Offline Patty
Final interest check form is up! The project has gone through some changes since the last update but we finally have a vendor! A huge thanks to Sneakbox Design for agreeing to be the worldwide vendor for the board
I know for some that a single vendor based in the US is not ideal and I truly apologize to those who are unable to purchase the board due to this, I decided to go this route to make things easier on me as this is my first time designing and trying to get a project into GB, it also allowed me to reach the lowest price I could at the given MOQ and number of color options for the board, so once again I am really very sorry I decided not to include international vendors this time, I still hope that you'll consider joining the GB if it is feasible for you
Also, thanks Lightning for posting pictures of the 3rd proto! It looks awesome and I'm glad you enjoyed the build!
Offline itsazly
    • website place
very excited about this board!!! can't wait for gb :3
