Author Topic: [IC] Gina: A Highly Versatile Macro-Numpad - Pricing, GB Dates & Vendors Update  (Read 11869 times)
Offline KeebCats
    • KeebCats
Introducing...
Gina by KeebCats
A highly versatile Macro-Numpad
In collaboration with James AKB and Cutie Club, KeebCats proudly presents Gina - a Macro-Numpad that boasts multiple layouts designed to suit 60% and 65% form factors.
Check out the UPDATED IC Form: https://kbcats.co/GinaICForm
Official Product Page: https://keebcats.co.uk/products/gina-macro-numpad-by-keebcats
A prototype of rev. 2.
All images in this post are of actual prototypes and are not renders unless specified.
Layout options for Gina
More Images of Gina: https://gallery.gina.keebcats.co.uk/
The story behind Gina
"My goal was to create a numpad that could sit perfectly next to my 60%/65% boards while maintaining full functionality. So I reached out to James AKB in 2022 to help make it happen.
James AKB suggested we add the option to flip the numpad's PCB, allowing for regular & southpaw layouts, right-hand & left-hand macro columns and an ortho-linear layout. This was made possible with the help of Cutie Club, who moved the MCU onto the daughterboard, allowing the main PCB to flip and be soldered on either side.
To keep costs low, we used a simple sandwich mount style and added relief cuts to slightly dampen the sound and add some softness to the pad. After many revisions, we're incredibly proud to present Gina. Named after my adorable cat who loves small spaces and makes awkward but cute eye contact."
- NorrittMTG
The real Gina in all her glory - the inspiration behind the Macro-Numpad: https://imgur.com/a/xjmpnaK
Features
- Versatile Macro-Numpad: This board is designed to be used both as a numpad and macropad.
- Unique Soldered PCB design as it can be flipped using a daughterboard; it does not require reflashing if you decide to flip it
- Hotswap PCB Options with Numlock LED(Fixed Standard or fixed Southpaw)
- Compatible with VIA/QMK
- CNC Full Aluminium Body
- Sandwich mounting with flex cuts
- Plate options: Aluminium (with flex cuts), Black POM (no flex cuts), Black POM (with flex cuts), Woven CF (with flex cuts)
- Compatible with 1.6mm stabilisers: TX Stabs, Durock, GMK etc.
- Option for solderable LED (this will not come with the board) in both standard and southpaw NumLock keys
Specifications
- Layout: Standard, Southpaw, Ortholinear Standard, Ortholinear Southpaw
- Weight: 480g~ fully built with Aluminium Plate
- Height: 7 Degrees Typing Angle, 19mm front height, 32mm back height
- Dimensions - 111mm x 111mm (Length x Height)
- Confirmed Colours: E-White, E-Black, Anodized Silver/Grey, E-Pink, Anodized Green
- Pricing:
                    USD  SGD   EUR  GBP
Soldered      |135 | 196 | 149 | 129 |
HS left/right |139 | 202 | 154 | 134 |
Vendors
- US & Canada: SpaceCables
- UK & EU: KeebCats (Tax in pricing is included for UK and EU member states)
- SEA: iLumKB
If you're interested in filling a vendor spot for Gina, please let us know in the IC form!
Dates
- IC begins: Mid-February 2023
- IC ends: June 2023
- IC Update: May 2023
- GB begins: June 16 2023 (TBC)
- GB ends: July 16 2023 (TBC)
- Shipping: 3-6 months, depending on order volume
Get in touch
- Discord: https://kbcats.co/KeebCatsDiscord
- Instagram: https://www.instagram.com/keebcats
- Gina IC Page: https://keebcats.co.uk/products/gina-macro-numpad-by-keebcats
To-do
- Creating more content of Gina, including build streams, content creators and sound tests
- Iterate on feedback based on IC feedback
- Find regional vendors for Gina
- Colour Match new prototypes
- Creating a build guide
Updates (18/05/23)
- Hotswap prototypes have been made and are currently being tested.
- Colour Matching for new latest round of prototypes.
- E-Pink proto is ready and looking amazing. Final colours have been selected.
- Gina IC form V3 with updated questions & space for Content Creator, Email Signups and Vendor outreach.
- Estimated pricing added, with SpaceCables the main NA vendor, iLumKB as SEA Vendor,  KeebCats will cover UK and EU.
- GB Dates Updated (TBC)
Special thanks to
James AKB: https://alchemistkeyboards.com
Cutie Club: https://cutieclub.cc
roscats: https://roscats.carrd.co/
Thanks for reading! Make sure to fill out the IC form to give us your feedback, and let us know if you want to get your hands on Gina!
« Last Edit: Fri, 26 May 2023, 15:40:17 by KeebCats »
Offline Something_Magical
Re: [IC] Gina - A Highly Versatile Macro-Numpad
« Reply #1 on: Mon, 13 February 2023, 19:17:36 »
Hey, this looks great! Love that there's the option for south paw and the macro row will be invaluable too. GL with your IC, I'll be waiting to get one of these :)
Offline Patty
  • do u like my cat yes or no
« Reply #2 on: Mon, 13 February 2023, 19:59:09 »
I'm in love with the layout graphic, that is adorable
Great IC, cool idea of having a macro column on a numpad, good luck!
Offline mini_ninja_64
« Reply #3 on: Tue, 14 February 2023, 04:54:55 »
OwO
Offline Helskor
« Reply #4 on: Tue, 14 February 2023, 06:26:31 »
Looks great, very interested!
Offline KeebCats
    • KeebCats
« Reply #5 on: Thu, 16 March 2023, 15:11:20 »
Update (16/03/23)
- Hotswap PCBs are currently in the works for both Standard (Right Hand) and Southpaw (Left Hand) layouts. These will be fixed layouts.
- E-Pink Case Colour Coating will be provisionally offered. The case is yet to be colour matched accordingly and needs to pass rigorous QC, however, due to popular demand it has been added as an option.
- Pending New Prototype Samples
- Revised Gina IC form with updated questions and a space for Content Creators to get in touch with us about promoting Gina
- NA Vendor Confirmed for Gina, more info to follow soon.
« Last Edit: Fri, 31 March 2023, 10:03:38 by KeebCats »
Offline Alva_Works
« Reply #6 on: Fri, 17 March 2023, 10:39:19 »
Reserved, so reserved.
Offline KeebCats
    • KeebCats
Update (31/03/23)
- Hotswap PCBs are in testing and should be ready in time for promotional content!
- E-Pink Case Colour is now guaranteed (colour matching still provisional)
- Pending New Samples
- CannonKeys confirmed as NA vendor
- US/NA Vendor TBC
- GB Dates Added
- Gina IC Form V3 with email sign-up notifications, revised questions and vendor application spot.
- Pricing Added
« Last Edit: Tue, 18 April 2023, 15:48:25 by KeebCats »
Offline KeebCats
    • KeebCats
Update (18/05/23)
- Final Phase of IC has started, now gearing towards GB
- SpaceCables confirmed as NA vendor, IlumKB confirmed as SEA vendor. Asia Vendor TBC
- E-Pink Case Colour is now guaranteed (colour matching has been confirmed)
- Anodized Green is the final optional colour (colour matching pending)
- Pending New Samples Colour Matching
- Final GB Dates Added
- Pricing Added, Final Pricing TBC
Offline drunken_sailor
  • I'm from KeebCats!
    • KeebCats
