Author Topic: [IC] KKB Miami Dawn (Dusk R2) - US pricing and dates confirmed!  (Read 25382 times)
Offline nostyle_au
« on: Mon, 13 February 2023, 18:32:54 »
KKB Miami Dawn
Discord | IC Form
A new day arrives for a classic keycap set. KKB Miami Dawn is a rerun of Miami Dusk with improved kitting and availability. Manufactured using double shot ABS by Keykobo.
Kitting:
All in one base kit featuring support for many layouts including varying bars.
A collaboration with Hibi! The palm tree novelty on an anodised aluminium keycap with MG1 matched infill.
Colours:
Colours are simple, magenta and cyan on beige. Specifically MG1, TU2, U9 and L9. Keykobo claims to be capable of matching GMK colours 1:1.
Samples:
Vendors:
OCE: Daily Clack
USA: Mekibo
CA: Apex Keyboards
EU: KEYGEM
UK: Proto[Typist]
SEA: Hex Keyboards
MENA: SandKeys
Pricing:
Mekibo - 85 USD
Daily Clack -
Apex Keyboards -
KEYGEM -
Proto[Typist] -
Hex Keyboards -
SandKeys - 315 AED
Dates:
The set will run from the 30th of March to the 27th of April
Board Renders:
Board Photos:
Thanks to:
- Joe of UKKeycaps for providing permission to rerun this set
- ankit for your help with kitting and bouncing ideas off of
- justterry for graciously providing board files for renders
- would for doing the same
- and rainkeebs too
- elvenmonster for the fabulous photos of the original set
« Last Edit: Wed, 22 March 2023, 21:19:34 by nostyle_au »
Offline nostyle_au
Re: [IC] GMK Miami Dawn (Dusk R2)
« Reply #1 on: Mon, 13 February 2023, 18:33:17 »
Q&A:
  • Why the blank winkeys?
    This is to match my two other favourite sets; the 2015 runs of RA and Olivetti
  • R5?
    The goal with this run is to stay close to the original run while improving compatibility. I'm personally not a fan of R5 in base and I expect it would struggle as a child kit, I don't want to offer a kit I expect to fail.
  • UK ISO?
    While I understand UK ISO was supported in the base kit of R1 the goal of R2 is to get this set made. The market has changed a lot and this set is running in a much different format to R1, for starters there is a focus on support worldwide due to increased vendors. Therefore it makes most sense to target physical compatibility in most cases, specific language legend support is an extra cost the likely >95% of users won't benefit from. That said I will explore an international kit, I've had a lot of requests for this so I'm happy to investigate.
    Due to the change to Keykobo UK ISO has become economically viable.
To Do:
  • Add 1u supers - Blanks will remain alongside
  • Change Print to Prt Sc
  • Add front print to Prt Sc and Pause
  • Merge kits
Updates:
  • Added 2x 1u Supers
  • Merged base kits into one
« Last Edit: Wed, 01 March 2023, 19:10:32 by nostyle_au »
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Mon, 13 February 2023, 18:35:21 »
hi nostyle
Offline mr_foggy
  • neue = nope
« Reply #3 on: Mon, 13 February 2023, 18:38:32 »
yes
Offline B_D
    • bdskeyboards
« Reply #4 on: Mon, 13 February 2023, 18:41:03 »
I will buy 3  :p
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Offline elvenmonster
« Reply #5 on: Mon, 13 February 2023, 18:49:31 »
Best set of 2023.
Offline dededecline
    • Linktree
« Reply #6 on: Mon, 13 February 2023, 18:50:41 »
Is the lack of legends on the 2x 1u Super keys intentional?
Offline nostyle_au
« Reply #7 on: Mon, 13 February 2023, 18:53:17 »
Yep, blank winkeys are to match my two other favourite sets; the 2015 runs of RA and Olivetti
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #8 on: Mon, 13 February 2023, 18:54:27 »
wow ankit is a genius including ansi support
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #9 on: Mon, 13 February 2023, 18:54:40 »
Woah.
Ne accent Magenta, Cyan keys avail?
What would it look like with CP instead of L9?
3 key 40s  :thumb:
Ne mod pipe, mod tilde avail?
Ne front-print avail?
Blank 1u Super-keys is funky  :eek:
« Last Edit: Mon, 13 February 2023, 19:02:23 by twitchytheinsideman »
Offline dededecline
    • Linktree
« Reply #10 on: Mon, 13 February 2023, 18:59:53 »
The 1u blanks are personally a dealbreaker for aesthetic reasons but at least it's intentional.
I'd suggest at least considering mod pipe/tilde, r3/r4 pg up/pg dn, and a second 2.25u shift.
Offline ankit
« Reply #11 on: Mon, 13 February 2023, 19:01:52 »
why are you here
Offline nostyle_au
« Reply #12 on: Mon, 13 February 2023, 19:02:05 »
Woah.
3 key 40s  :thumb:
Played around with accent keys, wasn't a huge fan. If you're after some Ankit is running WOB Essentials which includes CMYW anyway so I wouldn't want to step on his toes.
CP in place of L9 would be good in my mind, however main goal here was a rerun of the original set with improved kitting, if people would prefer CP in general I'm happy to look into it.
No mod pipe or tilde  :mad:
Front print is being considered, will continue to explore it. Original set offered it so might be worth doing so here too.
Offline nostyle_au
« Reply #13 on: Mon, 13 February 2023, 19:03:43 »
Thanks for the feedback, will definitely consider. I may look into including 1u supers and having the blanks as additional keys if it's too divisive of a decision.
    • Twitchy Homepage
« Reply #14 on: Mon, 13 February 2023, 19:05:42 »
Oh. Yeah, you are right.
 :thumb:
Offline dededecline
    • Linktree
« Reply #15 on: Mon, 13 February 2023, 19:06:00 »
I honestly like that idea, as the blanks are effectively novelties
« Reply #16 on: Mon, 13 February 2023, 19:06:15 »
looks great, nice work
miami nights next
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #17 on: Mon, 13 February 2023, 19:20:19 »
why are you here
I want win95 logo
Offline HappyB0T
  • I'm a Piggie
« Reply #18 on: Mon, 13 February 2023, 20:50:17 »
60 / TKL looks fine with the blanks - HHKB is hilarious looking to me. This is fun. Grabbing 2 bar kits at least thanks for kitting it this way!
Offline TheIcyKoala
« Reply #19 on: Mon, 13 February 2023, 22:09:39 »
Ah man I remember missing out miami dusk near the time I started getting into custom keyboards because I didn't want to order from mechsupply in UK. Glad to see it's getting re run, GLWIC  :thumb:
Offline finalarcadia
« Reply #20 on: Mon, 13 February 2023, 23:56:57 »
In very hard.
Offline Seunghyun Lee
« Reply #21 on: Tue, 14 February 2023, 00:17:58 »
i hope mod pipe, tilde and accent enter would include in base kit and also R5 and winkey as a child kit
Offline whirlwind
« Reply #22 on: Tue, 14 February 2023, 00:37:20 »
This is hot, let's go!
Offline mr_foggy
  • neue = nope
« Reply #23 on: Tue, 14 February 2023, 03:24:26 »
the original had a GMK novelty R1 cap, if it doesn't add too much to the basekit price, it might be nice to have it
Offline LMarci
« Reply #24 on: Tue, 14 February 2023, 06:18:09 »
Nut
Offline actress
« Reply #25 on: Tue, 14 February 2023, 06:18:43 »
please reconsider adding r5
Offline sirieous
  • help
« Reply #26 on: Tue, 14 February 2023, 07:56:51 »
very lit
Offline Phractals
« Reply #27 on: Tue, 14 February 2023, 09:46:28 »
This is so good. Do you have an estimate of when you wanna run this?
I think including 1u Supers would be the right move but i also like the 1u blanks.
Please consider hitting up Oblotzky to vendor this for EU.
« Last Edit: Tue, 14 February 2023, 09:49:49 by Phractals »
Offline nostyle_au
« Reply #28 on: Tue, 14 February 2023, 16:51:59 »
Not quite sure on when this will end up running at this stage, need to sort out vendors before I'll have any clue in that regard. Also don't want to rush it as I want to action feedback from the IC and will need some time to do that.
I think I'll be adding the 1u Supers in the end. I'm trying to decide between Super/Fn or Win 8 logo/Menu icon. I've added that to the IC as a question to gauge people's preferences for the time being.
Offline aicyborg
« Reply #29 on: Tue, 14 February 2023, 19:13:21 »
Please consider adding ISO-UK to base since originally it was present. I understand this is unlikely and you've likely intentionally omitted it, but... gonna shoot my shot and ask.
Offline nqbshas
« Reply #30 on: Tue, 14 February 2023, 21:47:07 »
Super nice set. Please include the front print :)
Sent from my SM-G998B using Tapatalk
Offline Moods
« Reply #31 on: Tue, 14 February 2023, 22:04:00 »
nostyle? more like yesstyle  :thumb: GLWIC
Offline nostyle_au
« Reply #32 on: Sun, 19 February 2023, 00:06:02 »
Confirmed a few vendors - Still working on USA, CA and EU.
Added the 1u Super keys  :thumb:
Offline mamahuhu
« Reply #33 on: Wed, 22 February 2023, 09:01:28 »
LGTM, GLWYIC!
Can't wait for your GB  :cool:
Offline offbrandbiscuit
« Reply #34 on: Wed, 22 February 2023, 10:50:23 »
This looks hard af man, hope this goes to GB. Would love to get a set if it does. Might be interesting to look into getting windowed child kit for it
i like fire trucks and moster trucks
Offline guypigeotto
  • beige baby
« Reply #35 on: Thu, 23 February 2023, 20:24:17 »
this is one of the beige sets of all time
having borrowed the set in the past, I can confidently say it’s great and I’m keen to see it in a proper form!
i made gmk handarbeige+
Offline NSMN
« Reply #36 on: Fri, 24 February 2023, 12:30:05 »
This is great
Offline mr_foggy
  • neue = nope
« Reply #37 on: Sat, 25 February 2023, 05:22:25 »
EU: KEYGEM
hearfelt thanks for this
Offline nostyle_au
« Reply #38 on: Mon, 27 February 2023, 22:51:34 »
Quite a major update, so here goes;
Manufacturer:
I was quite successful in finding vendors for majority of regions, however US proved to be difficult. Understandable a large majority of vendors are hesitant to take on GMK projects due to large backlogs of GMK sets that they're yet to receive, and as such would like to see these decrease before working with GMK more. For this reason I began exploring different options in terms of manufacturer/profile.
DCS was considered, I do quite like the profile, and the quality is a known factor. However Signature Plastic's timelines aren't really any better than GMK's at this stage, with many vendors experiencing similar queues. Two other options suggested were DCX and Keykobo. I decided to reach out to Keykobo for information and was offered a sample of an existing set they've run.
This sample arrived Monday and overall I was blown away by the quality, very much comparable to GMK's. These were the observations I reported to the vendors I have been working with:
  • Dimensions are all identical to GMK's from my measurements; cap width, height, wall thickness and how high they sit on a switch are all the same.
  • Caps seem to mount firmly on switches, no issue with looseness or being too tight. (I've personally heard about issues with JWK being slightly loose, however I can't really fault a keycap for JWK switches being different to Cherry when other manufacturers don't appear to have issues)
  • Legend alignment appears to have no issues. A minor quirk on the '%' key, it looks a tiny bit squished.
  • This set only included the 7u bar, but it's absolutely dead straight, no lift at all when checking for warp.
Based on the other vendor's reactions to the quality, especially for the price, we have decided to go ahead with Keykobo to manufacture this set.
Kitting:
Due to this change in manufacturer it was decided that it would be best to merge the two kits into a single kit. Therefore the bars kit will no longer exist and will instead be included in the base kit.
I'm considering adding UK ISO as it's been heavily requested and won't affect pricing much at all really. This isn't quite decided yet however I will play around with the idea.
I will try to get permission from Cherry to include the Cherry novelty in this kit, however it remains to be seen if they will allow it. Fingers crossed.
Vendors:
I'm happy to announce that vendors are all locked in now, Mekibo is joining and as such the vendor list will be:
OCE: Daily Clack
USA: Mekibo
CA: Apex Keyboards
EU: KEYGEM
UK: Proto[Typist]
SEA: Hex Keyboards
The only uncertainty is if MENA will have a dedicated vendor, Sandkeys is always welcome to run any project I work on but they will decide closer to the GB as to whether or not to join this one.
We are looking to run the Group Buy in late March if all goes well. Pricing to be confirmed soon.
Any questions please drop a comment here or reach out to me on Discord  :thumb:
« Reply #39 on: Mon, 27 February 2023, 23:02:48 »
I think keykobo is really good. Also this means that our sets will deliver much sooner than GMK, so I will support :)
« Last Edit: Tue, 28 February 2023, 19:17:22 by elvenmonster »
Offline dcsenjoyer
Re: [IC] KKB Miami Dawn (Dusk R2) - Vendors confirmed!
« Reply #40 on: Tue, 28 February 2023, 03:40:28 »
kkb bow(kkb x geonworks)
6u is shorter than 6u from gmk(wob)
https://imgur.com/a/9uOgAcf
https://imgur.com/a/Enedp8V
3u has stems for 2u wire
https://imgur.com/a/cnXOlSm
Offline nostyle_au
« Reply #41 on: Tue, 28 February 2023, 04:02:03 »
I’ve raised this with them and they’ve fixed this issue since the Geon run. It’s no longer an issue according to them. I’ve attached the photo he sent me of the fixed bars, he’ll also be sending me a 6u sample along with the colour samples I’ve requested.
Offline VXQN
« Reply #42 on: Tue, 28 February 2023, 04:23:22 »
Changing manufacturer to Keykobo is a great idea. Add me to the list of people that would love UK ISO. If Cherry logo is a no-no, then how about something else "Miami" like a palm tree or a flamingo?
Offline mr_foggy
  • neue = nope
« Reply #43 on: Tue, 28 February 2023, 15:18:14 »
excited for the manu change. keykobo really is comparable to GMK quality wise, price will benefit too.
nice! day 1 purchase for me.
« Reply #44 on: Wed, 01 March 2023, 00:28:27 »
Still in lets go
Offline involuntarysoul
« Reply #45 on: Wed, 01 March 2023, 12:28:23 »
kind of hard to see the alpha in the render, it blends in too much, do you have photos of the samples?
Offline nostyle_au
« Reply #46 on: Wed, 01 March 2023, 16:33:25 »
Keykobo is providing me with samples for the following:
- Manufacturing capabilities (A different set in different colours showing the quality of their product)
- Colour matching (Colour chips showing that they match GMK 1:1)
As such I don't have a photo of a sample of the exact set from them. There are however photos of R1 from GMK in the original post, Dawn/R2 from Keykobo will be close to identical based on the samples being approved.
Offline nostyle_au
Re: [IC] KKB Miami Dawn (Dusk R2) - US pricing and dates confirmed!
« Reply #47 on: Sat, 04 March 2023, 14:09:13 »
We will be going live with a GB from the 30th of March! Pricing will be based off US pricing of 85 USD - regional vendor pricing to follow closer to GB.
Offline HugoChowsky
« Reply #48 on: Sat, 04 March 2023, 17:53:24 »
What is the estimated delivery for this?
Offline nostyle_au
« Reply #49 on: Sun, 05 March 2023, 05:36:37 »
~4 months is the likely timeline based on manufacturing lead-time provided to me by KKB.
