Author Topic: Trouble Flashing TMK firmware (IBM model F XT, Teensy 2.0, QMK Toolbox)  (Read 4202 times)
Offline gumilarganjar
Hello, I found trouble flashing TMK firmware using QMK toolbox for my teensy-converted IBM model F XT. Flashing soarer's converter using this method was fine (currently typing on it), but boot-loop or flash-loop happened when I tried flashing TMK.
Here is the error:
*** Halfkay device connected: (null) (null) (16C0:0478:0120)
*** Attempting to flash, please don't remove device
>>> teensy_loader_cli -mmcu=atmega32u4 /Volumes/GG NVME/Download NVME/unimap.hex -v
    Teensy Loader, Command Line, Version 2.1
    Read "/Volumes/GG NVME/Download NVME/unimap.hex": 28390 bytes, 88.0% usage
    Found HalfKay Bootloader
    Programming...error writing to Teensy
Any help or explanation would be greatly appreciated.
Offline Sup
Re: Trouble Flashing TMK firmware (IBM model F XT, Teensy 2.0, QMK Toolbox)
« Reply #1 on: Sun, 19 February 2023, 08:06:44 »
Can you try to flash it from the commandline?
current
Coming soon
« Reply #2 on: Sun, 19 February 2023, 10:34:08 »
Unfortunately, my knowledge and experience in coding is almost nonexistent :(
Anyway, thankyou for the suggestion.
Offline Sup
« Reply #3 on: Sun, 19 February 2023, 14:57:01 »
it's not coding. It's just putting your keyboard into bootloader mode and then using the command to compile with FLASH parameter with it.
current
Coming soon
