Author Topic: IC] Ginkgo 65 Pro Kit-the beautiful board is back and upgraded with new designs  (Read 7724 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
    Hi Everyone,
    Thank you for following Ginkgo65 pro project so far. Ginkgo 65 Pro GB is live on March.15th from almost all vendors.
    Ginkgo65 R2 Product Page
    GB Schedule and Price
    * GB Time: March. 15 - April. 3, 2023
    * GB Price: 259 USD (Vendors' price maybe slightly different)
    Ginkgo65 Pro Gallery
    Ginkgo65 Pro Render
    Ginkgo65 Pro Keyboard Kit Render
    Ginkgo65 R2-E-white x Copper
    Ginkgo65 R2-E-white x Gold & Black x Copper
    Ginkgo65 R2- Black x Burgundy
    Ginkgo65 R2-Blue x Blue & Blue x E-White
    Ginkgo65 R2- Purple x Silver & Champagne x Gold
    Ginkgo65 R2- Silver x Silver & Champagne x Copper
    Ginkgo65 Pro Recent Reviews/Live streams updated
    Xinxinwong- Blue top case x Blue bottom case
    Clackbait- Champagne top case x Gold bottom case
    Apiary- Blue top case x E-white bottom case
    Alexotos- Black top case x Copper bottom case, March. 24th
    Pre-order Bonus: Anodized Gold Blocker
    Check the Anodized Gold Blocker here
    A free Ginkgo Anodized Gold Blocker will be gifted to orders placed before March 17th (Deadline: March.16th-00:59, Beijing Time) for Ginkgo65 Pro GB from the Wuque and vendors.
    Vendor List (To be updated)
    US: Cannon Keys
    Canada:Mech.land
    Oceania:Keebz N Cables
    EU:Mykeyboard
    UK:Proto[Typist]
    Russia:Geekboards
    Singapore:iLumkb
    Malaysia:Rebult
    Vietnam:Soi Gear
    Philippines:Zion Studios
    South Korea: Varo
    Indonesia: Keebsmark
    TW:Inpad
    TH: NTCH Keys
    Rest of the world:Wuque Studio
    What's New with Ginkgo 65 R2
    Appearance upgrade
    * New case colors
    * PVD logo weight
    * Optional and removable blocker/url]
    * Default flex cut and non-flex cut PCBs are available.
    PCB Layout upgrade
    Hotswap PCB
    * Compatible with stepped capslock and 7U layout
    Solder PCB
    Multi layout, supports split space bars, ISO enter, compatible with multi layout plates.
    Gasket Mounting Upgrades
    * Using the new Gasket Module method
    Plate flex cuts designs
    Different plates have different flex cuts to give a diverse feel and typing sound.
    Ginkgo65 info
    * Typing angle: 7 degrees
    * Front Height: 19.18mm
    * Dimension: 320.39 x 119.47 x 32.72 (mm)
    * Weight (unbuilt): 1.3kg or 2.87 lbs
    * Case material: 6063 Aluminum
    * Mounting Method: Gasket Mount using gasket module
    PCB Specifications
    * Hot-swap PCB: 1.2mm thick, with Ai03 daughterboard
    * Support QMK / VIA
    * Flex cuts or non-flex cut
    * ESD Protection
    What’s included
    * Aluminium Top & Bottom Cases
    * Default PC Plate
    * Hotswap Flex cut/Non- Flex cut PCB
    * PVD Logo Weight
    * Poron Dampener Kit
    * Gasket Modules
    * Storage Case
    * AI03 daughter board
    * JST cable
    * A set of M·ONE Stabilizers
    * Keyboard feet
    * Screw and hex screwdriver
    * Silicone gasket sleeves
    Thank you for taking the time to read our post. Please sign up for your vendor's mailing list and join Ginkgo discord channel for more frequent updates.
    [/list][/list]
    « Last Edit: Wed, 15 March 2023, 11:14:57 by Ckeeb »
    Offline N3OG3M
    Re: IC] Ginkgo 65 R2 by M.one studio comes back in a new style
    « Reply #1 on: Mon, 27 February 2023, 05:47:45 »
    Love the upgrades on R2.
    Would be super nice also if all options would be independently selectable.
    Eager too see more updates ;)
    GL on IC :thumb:
    Offline Ckeeb
      • MELETRIX
    « Reply #2 on: Tue, 28 February 2023, 19:30:45 »
    GL on IC :thumb:
    Thank you for your support, you can share your ideas on the Ginkgo65 IC form and we will consider them, thank you very much! :)
    Offline RyukG
    • Discover & Manufacture
    « Reply #3 on: Wed, 01 March 2023, 08:12:47 »
    R1 is good enough, R2 brings unexpected upgrade!!!
    Offline Ckeeb
      • MELETRIX
    Update!
