Author Topic: Hellcat kit | Vortex X MiTO  (Read 4637 times)
Offline vortexkeyboard
« on: Thu, 02 March 2023, 02:47:57 »
297089-0
Some of you might know that few years ago, we have announced the collaboration with MiTO.
At the same time, a lot of you have been patiently waiting for us to make it become available.
Right now, we are very happy to announce that Hellcat Kit will become available around late May!
Hellcat kit is a 65% keyboard kit that comes with a keycap set designed by MiTO and switches will not be included.
Since Hellcat Kit has underflow RGB, the case material of the Kit is acrylic with MiTO’s logo at the bottom of the case and the PCB is QMK/VIA/Vial compatible.
Specification of the kit:
- Wired
- ANS 65% layout
- Programmable via QMK/VIA/Vial
- N-Key Rollover
- Translucent CNC'ed acrylic housing (blasting)
- RGB Underglow
- PCB: 1.6 mm Thickness
- Tray Mount Structure
- Customizable RGB Using VIA/Vial Software
- DSA PBT Dye-Sub Keycaps
- USB Type-C Connectivity
In the kit, it includes
- CNC'ed Acrylic Case x1
- FR-4 Mounting Plate x1
- PCB kit (including PCB/internal screw kit/silicone switch dampener) x1
- USB Daughter Board x1
- Silicone Switch Pad x1
- DSA PBT Dye-sub Keycap Set designed by MiTo x1
- Gold Screw-in PCB Stabilizers Set x1
- Scerw Set x1
- Rubber Feet Set x1
- Carrying Case x1
Vendor
Vortex Keyboard
ISO version :
-KEYGEM
ANSI version:
-Mechanical Keyboard
-clickeys.nl
-StacksKB
-mechanicalkeyboard.co.id
-Rebult Keyboard
-Pantheonkeys
297091-1297093-2 [ Specified attachment is not available ]
Offline Nuap
Re: Hellcat kit | Vortex X MiTO
« Reply #1 on: Thu, 02 March 2023, 18:55:18 »
Nice  :thumb:  is it true that this doesn't come with any warranty at all? What if the PCB is malfunctioning?
