Author Topic: [GB] IV Kanketsu - Live March 4 - April 4!  (Read 13320 times)
Offline STUDIOBLB
« on: Fri, 03 March 2023, 14:47:09 »
IV KANKETSU
Kanketsu is a Japanese design philosophy that is rooted in simplicity. The word itself can translate to “completion”, “simplicity”, or “brevity”.
The philosophy teaches that true simplicity can often be a complex path requiring careful choices and intentional decisions.
We are very pleased to be working on this project with IV Works, a long time friend of the Studio and collaborator on other adventures!
GROUP BUY INFO
The Kanketsu Collection will be available to purchase during the group buy starting March 4 through April 4. Production is estimated to take 90 days from the conclusion of the group buy.
VENDORS
NA: IV Works
EU: MyKeyboard.eu
UK: Proto[Typist]
CN: zFrontier
AU: SwitchKeys
JP: BaseKeys
SEA: iLumKB
VN: Shibay Mech
CA: DeskHero
KITTING
Just like IV Ashes, this release features a single kit with a wide compatibility and includes all novelties and spacebars. Kanketsu is Cherry profile made with extra thick 1.55mm dye-sublimated PBT.
With knowledge gained from the successful IV Ashes run, IV Works was able to improve both pricing and production time.The set will have a group buy promotional price of $79.99 with a 90 day production timeline.
As per IV Work’s modus operandi, we have physical samples in hand of all items to share before the buy.
SAMPLES
We have samples of the full kit on hand!
Here are some photos of one of the sample sets. Needless to say, we are extremely pleased with the results.
DESKMATS
For this release, we wanted to give people the option to go with a standard sized large deskmat or a custom sized mini mat! Mix, match, and stack to your heart’s delight.
Mameshibori Mechmat: A small dependable mat, not unlike the dyed tenugui that inspired it.
The perfect size for a TKL, or use a smaller board if you want to show off a pop of colour underneath.
Doodle Deskmat: A nod to the quick doodles that fill the corners of our notebooks, and the scribbles when you need to test out a new pen.
A large canvas on which to work, play, and live.
SWITCHES
A fun tactile switch to complete your Kanketsu build. Designed for typing accuracy with medium tactile bump and smooth travel on a responsive spring.
Building off the groundwork of the Darkroot switch produced alongside IV Ashes, this new switch has the same thick-pole but in a tactile variety. This new thick-pole stem increases
feedback without a harsh bottom out. This stem mimics the feel of a long-pole stem by increasing the strike surface between the pole and bottom housing. It generates more feel and
sound without the negatives of the shorter travel and fatigue of the long-pole hitting the bottom housing. Stem rails have also been thickened to decrease wobble. Features a 22mm x 65.5
gram Double Spring for a crisp upstroke.
HPE is softer than traditional switch plastics for a more comfortable typing experience. It also has the smoothest surface finish for clean travel that does not require lubrication. The switches
are manufactured dry so you can tune to your liking. Most testers have found lubing the stem and springs offers the best experience. Housing has tighter tolerances so films are not necessary
but can be used to change sound profile.
LISTEN TO THE SOUND TEST HERE
RELICS
Row 1 keycap featuring the scribble novelty. The design is machined from polycarbonate, then filled with enamel by hand.
- Choice of red or charcoal enamel infill
- Blasted polycarbonate
- Enamel fill
- Special NFC box
Check out some photos of the production samples we got!
CABLE
Premium USB cable color-matched to IV Kanketsu. A collaboration with KKona. Exclusive to IV Works
- Cerakoted LEMO style connector
- USB A to USB C with CNC milled terminals
- Gold plated terminals
- 7" device end, 5' host end
- Double sleeved
- Hits different
RUG
Premium rug featuring the Kanketsu Scribble designed to fit perfectly under a desk. Heavy weight yarn stitched into a high pile with fully finished bottom.
All processes are hand done and each item in the limited run is individualy numbered. Exclusive to IV Works
- Handmade item
- Thick pile
- Fully finished bottom
- 60cm x 60cm
COLLABS
Resin Artisan Keycaps: DREAD Keys - https://discord.gg/gTkQ6zMA
Resin Artisan Keycaps: P.Craft - https://discord.gg/T6P5hUka
Resin Artisan Keycaps: Keyzen - https://discord.gg/YbchBu7R
CONTACT
For business inquiries, please reach out to us through email at studioblb.co@gmail.com
Join us in our studioblb Discord server!
Check out the IV Works Discord server!
Follow us on Instagram!
SPECIAL THANKS
Joe
Skydoki
Tom
T
Ian
You can support this project by adding the following BB code to your signature! Thanks!
Code: [Select]
[url=https://geekhack.org/index.php?topic=116299.0][img width=281 height=120]https://i.imgur.com/I8sGcsu.jpg[/img][/url]
« Last Edit: Sun, 05 March 2023, 11:34:05 by STUDIOBLB »
Offline STUDIOBLB
Re: [GB] IV Kanketsu - Live March 4 - April 4!
« Reply #1 on: Sun, 05 March 2023, 11:06:10 »
Reserved
Offline Wolff._.
  • Machinist
« Reply #2 on: Sun, 05 March 2023, 11:33:06 »
Finally  ;D
Offline jesse_le
    • Pcraft.Studio
« Reply #3 on: Sat, 11 March 2023, 04:12:08 »
I like it. GL w GB!
P.craft Studio | Artisan Maker | www.pcraft.studio | https://discord.gg/jZGkhDyuKB
Offline HazeAerospaze
« Reply #4 on: Tue, 14 March 2023, 03:52:53 »
like the creme. might cop.
Offline stidal
  • milo#3939
« Reply #5 on: Tue, 14 March 2023, 08:58:20 »
are the switches manufactured by tecsee
they're tecsee :(
« Last Edit: Wed, 15 March 2023, 23:41:06 by stidal »
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline POCO Estudio
« Reply #6 on: Tue, 14 March 2023, 09:20:03 »
ok,it's ok.
