Author Topic: [GB] DEADLINE STUDIO - New Retro #66 65% keyboard ( 4.16 ends)  (Read 11085 times)
Offline Deadline.Studio
Welcome to the group buy page for DEADLINE STUDIO,welcome everybody.
Firstly, thanks all for your attention and support.
Group  buy  date: March 16  -  April 16, 2023
This time  GB adopts two methods, a small stock + pre-order
keyboard Pricing:
Supplier taxes and shipping costs are different in different regions, if there are differences, please refer to the price of suppliers in each region
Shipping time: within three months after the end of GB
VENDORS:
US:keebsforall
EU:  KEYGEM
UK:  jae_prototypist
CL:  fancy.customs
MY:  mecha.store
INDO: curatedbykwok
OCE:  Allcaps.store
JP:  yushakobo.jp
TH:  febust.channel
VN:mokb.store
SG :  ilumkb
DEADLINE studio  // New Retro #66 // 65% keyboard set
[/left]
Colour option:
01 Silver anodized(E-coating green triangle bracket + white transparent PC)                                             02 Violet E-coating(anodized purple triangle bracket + gradual transparent PC)
03 Cream E-coating (E-coating cream triangle bracket + white transparent PC)                                          04 Orange E-coating (E-coating orange triangle bracket + white transparent PC)
05 Dark blue E-coating(anodized silver triangle bracket + black transparent PC)
Layout:
The two 1u on the far right can be desoldered and the ec11 knob can be welded after the hot-swap axle seat removed
Capslock supports hot-swap flip-chip axis left shift
Capslock supports CAPS indicator
WKL space line support: 1.5-1.5-6.25-1.5-1.25
WK space line support: 1.25-1.25-1.25-6.25-1.5-1.25
Two pcb options are available:
①  PCB is designed and produced by Mechlovin'Studio
Qmk/VIA supported
USB-C interface
②  bi-mode RGB ( Bluetooth 5.0 solution ,VIA supported,USB-C interface)
FR4                                                             English or Japanese② choose ①
Kit list:
Top case(Aluminum  anodized/E-coating)
Bottom case (Aluminum anodized/E-coating)
Front pack(PC)
Back pack (PC)
Left pack (Aluminum anodized)
Right pack (Aluminum anodized)
Decoration block (Aluminum anodized/E-coating)
Internal weight (PVD)
Weight badge (PVD)
Fr4 plate
Hotswap PCB
0.25u decoration block (Aluminum anodized/E-coating、PC)
Connecting rod (Aluminum  anodized/E-coating)
Triangle bracket (Aluminum  anodized/E-coating)
PCB decoration block (Aluminum  anodized)
Knob*2 (Aluminum  anodized/E-coating)
Poron bottom cotton
Poron sandwich cotton
Poron vibration-absorbing cotton
Ixpe pad
Silicone
foot-stick
Typing angle 7°
Typing height 22.5mm
Extras:
① triangle bracket                                        ② connect rod
③ PCB decoration block                                                 ④ Knob
⑤ plate
Due to the large typing angle,we design a wrist rest to sell together with the keyboard
REAL SHOT
To view the video, please move to ins DEADLINE studio
Thanks all for your attention and support.
Sincerely,
DEADLINE STUDIO
« Last Edit: Tue, 14 March 2023, 13:44:48 by Deadline.Studio »
Re: [GB] DEADLINE STUDIO - New Retro #66 65% keyboard ( 4.16 ends)
« Reply #1 on: Tue, 14 March 2023, 17:34:32 »
Approved :thumb:
Offline Lewis_Lyron
« Reply #2 on: Tue, 14 March 2023, 21:21:06 »
Real shots and renders look the same lol ;D
eat an enter
Offline Transistor
« Reply #3 on: Tue, 14 March 2023, 22:10:27 »
 :thumb:
Don't judge me -_-
Offline Fulanito
« Reply #6 on: Sat, 25 March 2023, 20:36:01 »
Hello, this looks great! Could you please share the specifications for the battery that work with the BT version? I could not find that on your website. Thank you!
Offline DojoMojo
« Reply #7 on: Wed, 29 March 2023, 01:19:34 »
What is the Bluetooth on the pcb? is this for connectivity and how would that work without an internal battery ?
« Reply #8 on: Thu, 27 April 2023, 12:38:37 »
Can hold batteries
