Author Topic: optical keyboard (gateron) + 2.4G ?  (Read 3648 times)
Offline mlmcasual
« on: Tue, 14 March 2023, 14:50:26 »
Hello!
Just wondering.. I am searching for a decent re-configurable wireless keyboard with optical switches..  Unfortunately the big box "gamming boards" .. logitech,corsair, etc.. are proprietary (and also overpriced)  so ruled out.
Does anyone know of a brand/manufacturer that checks off the following criteria?
Customizable kebyoard (hot swappapble) switches and keycaps
Can use Gateron OPTICAL switches
Wireless 2.4G
I can't seem to find one that meets all three..
thanks!
Offline PlayBox
Re: optical keyboard (gateron) + 2.4G ?
« Reply #1 on: Tue, 14 March 2023, 16:39:46 »
Hello!
Wireless 2.4G
2.4g is hard to find in more enthusiast keyboards also no keyboard supports both optical and mchanical switches and beetween these 2 i would get a mechanical switch keyboard (much more switch options and literally no diffference in function) as i said before 2.4 is unrealistic and i would settle on bluetooth or wired
thanks!
propably sent from my amazon kindle 10th gen
