Author Topic: Need a keeb between 70-95$ price range with 3 connectivity modes  (Read 4714 times)
Offline huskyhunter
Hi Geeks,
I am looking for a budget keeb for low 70-85 to high 100$ price range
What me looking for in the keeb
65% layout
Wireless
linear switches pre-lubed
Qmk/VIA supported or at least a software to remap keys
Rotary
gasket mount.
This is the closest one i could find but the keycaps suck https://epomaker.com/collections/65-keyboards/products/epomaker-ek68?variant=43765659074868.
 :D
« Last Edit: Fri, 17 March 2023, 05:28:35 by huskyhunter »
Offline Sygaldry
  • Edema Ruh
Re: Need a keeb between 70-95$ price range with 3 connectivity modes
« Reply #1 on: Fri, 17 March 2023, 15:55:15 »
Why not get the OEM that EK68 copied ?
GMK67 + lubed linears (gat pro yellow?) + whatever keycaps you want.
https://www.aliexpress.us/item/3256804812596037.html
This is the keyboard I use and it's great!
null
Offline DashanYYY
    • Unikeys
« Reply #2 on: Thu, 23 March 2023, 16:03:17 »
Maybe you could look at the Akko 5075B plus?
