Author Topic: Need Help - NEW pcb not working  (Read 48327 times)
Offline gandalftw
« on: Sun, 19 March 2023, 01:36:18 »
Hi,
I ordered a kit from Aliexpress (unfortunately).
https://www.aliexpress.com/item/1005003816846952.html?spm=a2g0o.order_list.order_list_main.70.1bda18026nyACz
Trying to use VIA and it won't find the pcb, from my understanding you need first to flash the pcb with the qmk firmware.
using the yd60mq_16led_via.hex provided in the pdf of the product brakes the pcb.
after firmware flashed non of the keys are working (keyboard tester) but via is able to see the pcb as YD60MQ.
to my understanding this firmware is not compatible with this pcb
hope someone can help because I couldn't find any firmware that will work with this pcb
Offline gandalftw
Re: Need Help - NEW pcb not working
« Reply #1 on: Sun, 19 March 2023, 06:08:58 »
The correct firmware should be Oni HHKB but I can't find any match for this name
Offline gandalftw
« Reply #2 on: Sun, 19 March 2023, 06:11:48 »
And by the way , what is this for a torture
Verification:
Type the letters shown in the picture
Listen to the letters / Request another image
Type the letters shown in the picture:
A popular serial bus for keyboard connectivity:
A popular keyswitch type, which has been increasingly cloned in recent years (abbrev, 2 letters):
A popular keyboard format (abbrev, 3 letters) which omits the numberpad normally present on a fullsize keyboard:
Offline DashanYYY
    • Unikeys
« Reply #3 on: Thu, 23 March 2023, 16:04:26 »
Is there an option on Aliexpress to talk to customer service? They might know how to solve it.
Offline gandalftw
« Reply #4 on: Thu, 23 March 2023, 16:17:56 »
I asked nicely YMDK over chat 2min problem solved
he send me the correct qmk firmware
but sorry will never post here again with all this stupid question , WTF are we childrens?
