Author Topic: [GB]N87 Alu metal suite  (Read 5203 times)
Offline Nizkeyboard
    • nizkeyboard
« on: Tue, 21 March 2023, 04:35:39 »
Hello, everyone, this is N+ Studio!
We are back! thanks for your support and love all the time!
In the past several years, we have launched Atom68 and Duo 82 Alu suite in succession and got a lot of good reviews, many folks often asked us for them and gave some valuable feeback, thanks so much to all of you!
We have kept them in our hearts and worked hard for these in the past, finally, after waiting for more than one year, today we will bring a new metal Electrostatic Capacity suite N87 to all of you.
N87 suite is just for NIZ X87 series keyboards not including waterproof version, it contains top/bottom case, inner parts and QMK PCB, this time they will be sold in stock and can be shipped quickly.
About Design:
(1)Appearance design
A simple and durable design, based on supporting the sandwich structure, minor adjustments to the frame ratio are made, and repeated modifications to the four round corners to achieve the most satisfactory appearance.
(2)Switch design
For the bluetooth switch design, in order to be better compatible with NIZ EC keyboard, the same press switch design next to ESC is used, and this switch can also be used as an ornament on the front of the keyboard.
At the same time, in order to ensure the stability of Bluetooth signal, a PC signal block on the bottom base was add.
(3)Bottom weight design
A overall introversion design on the bottom, a transparent electrophoretic brass is studded wtih the bottom case, the word N+ is revealed, that’s why named N87.
About Spec:
Alu Top/Bottom case:
Material: Aluminum
Size: Length*Width*Height( 36.4cm*14.4cm*3.4cm)
Weight: 2300-2450g
Color options:
Anodized-Burgundy red
Anodized-Space grey blue
Anodized-Matte silver
Anodized-Classic black
Typing angle:  7 °
Layout:
What's in the box:
Aluminum top case*1pc
Aluminum bottom case*1pc
Brass weight*1pc
PC signal block*1
Light guide for indicator light*2pcs
Poron pad*1pc
Silicone pad*1set
Foot pad*4pcs
Screws and screwdriver*1set
Type-C daughterboard
In stock sale link:
Alu Top/Bottom case
Inner parts(35g/45g):
EC switches
Conical springs
Costar stabilizers
Aluminum plate
EC silicone domes(35g/45g)
In stock sale link:
QMK PCB(wired):
N87 QMK PCB(wired),Type-C daughterboard
In stock sale link:
QMK PCB(wired)
About Price:
Alu Top/Bottom case: 198USD/set
Inner parts(35g/45g): 55USD/set
QMK PCB(wired): 70USD/set
In stock sale time:8:00 am, Mar.,24th,2023( GMT +8:00)
Qty: 100sets
Delivery time: within one week after order received
More information, you can join our discord/email or message us.
Note: we also have some ePBT keycaps for sale, the link is:
ePBT keycaps
If you like them, come on!
More pictures:
« Last Edit: Wed, 22 March 2023, 03:11:46 by Nizkeyboard »
Re: [GB]N87 Alu metal suite
« Reply #1 on: Wed, 22 March 2023, 16:03:05 »
Approved :thumb:
Offline drfilco
« Reply #2 on: Thu, 23 March 2023, 10:29:15 »
Honestly this seems super cool to me >.>
Offline menuhin
« Reply #3 on: Thu, 23 March 2023, 11:30:16 »
Such a great deal in terms of price and quality - it is all sold out I believe?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline bansheetango
« Reply #4 on: Fri, 24 March 2023, 04:21:49 »
That shipping tho...  :-X
