Author Topic: Switches Pressing Simultaneously After Desoldering  (Read 3790 times)
Offline Cosmonaut911
« on: Wed, 22 March 2023, 01:47:53 »
Hello
I need help or insight into what went wrong or generally what is wrong with this board.
Okay, I recently removed Kailh blue switches and soldered Gateron KS 3 Red switches into my old keyboard. at the beginning, I plug my keyboard to my pc and everything looks normal for the first 5 minutes until the capslock row down to numpad 6 pressing continuously. I decided to remove the switches from the Capslock row and it still pressing! I need help or solution to this problem.
Btw, this is my first soldering new switches into keyboard.
Offline Sup
Re: Switches Pressing Simultaneously After Desoldering
« Reply #1 on: Wed, 22 March 2023, 22:34:42 »
Not sure if this is the cause, but you seem to be missing a diode.
current
Coming soon
