Author Topic: [GB] Haimu Rococo R2 Tactile Switch 【GB Ends,Fulfilling starts soon】  (Read 3833 times)
Offline DashanYYY
    • Unikeys
297705-0
Hi everyone, this is DY from Unikeys. I am very excited to announce that we are launching the Haimu Rococo R2 Tactile Switch group buy today.
Link to Unikeys: https://unikeyboards.com/
297707-1
297709-2
297711-3
The Rococo R2 tactile switch is manufactured by Haimu. It comes with a specially designed RGB channel piece and a box stem to reduce stem wobble. It is the perfect switch for you if you love strong tactile switches (such as the Holy Pandas) and don't want too much stem wobble. The Rococo R2 also comes with a thin layer of factory lube to reduce leaf spring noise. It is very smooth and thocky stock. Personally, I would say it is good to go out of the box. However, for those who want their switches to be almost perfect, we recommend lubing them again slightly for an optimal experience.
Rococo R2 Typing Test: https://www.bilibili.com/video/BV1WT411Y737/?share_source=copy_web&vd_source=84758b864313c118cdc09844fe9ec8f1
Typing test on a Cyberboard:https://www.bilibili.com/video/BV1is4y157MK/?spm_id_from=333.337.search-card.all.click&vd_source=b8d2f30f6fb0941b00c723ed920aa5b5
Price: $4.80/10pcs
Spec:
Switch Type: Tactile
Top Housing Material: PC
Bottom Housing Material: PC
Stem Material: Modified POM
Operating Force: 40g
Bottom-out Force: 50g
Spring: 22mm gold-plated extended spring
Leaf Spring: gold-plated and strengthened
Pre-travel: 2.0mm
Total Travel: 3.8mm
Group buy timeline
GB Starts: March 24, 2023
GB Ends: April 10, 2023
Estimated Fulfillment date: Around April 15, 2023
The designer and factory let us know that the manufacturing should be done by April 15th, but the fulfillment date could be subject to change if there is any delay in manufacture or shipping. Please join our discord channel to get updates.
Welcome everyone to join our Discord to learn more about the GB: https://discord.gg/xprJb8Ta26
Mod Edit: Added price - please feel free to remove this note when you see it :thumb:
« Last Edit: Fri, 28 April 2023, 11:28:51 by DashanYYY »
Re: [GB] Haimu Rococo R2 Tactile Switch
« Reply #1 on: Thu, 30 March 2023, 10:36:18 »
Approved :thumb:
Offline DashanYYY
    • Unikeys
« Reply #2 on: Thu, 30 March 2023, 12:35:47 »
Offline DashanYYY
    • Unikeys
« Reply #3 on: Tue, 18 April 2023, 14:31:45 »
The Rococo R2 switches are being shipped to us by the factory. Shipping will start very soon. Thank you for your patience.
