Author Topic: What do you consider as a "clean" injection mold?  (Read 9352 times)
Offline KeyCapQueen
« on: Sat, 25 March 2023, 11:15:35 »
How do you distinguish a HQ from a low quality injection / keycap? References would be appreciated!
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: What do you consider as a "clean" injection mold?
« Reply #1 on: Sat, 25 March 2023, 11:32:22 »
Beyond if the legends are all clean looking while being placed properly & all the caps fitting & sitting how they are supposed to. Looking at the underside & how clean or sloppy the double/tripleshot is, is a good indicator of quality. Is there any flashing present in any of the caps is another good indicator (flashing is when you see a line where the molten plastic came together. If the temp is too low it allows for the plastics to not blend together well), then how big & visible the sprue marks are is another indicator of quality I will use to judge the overall quality of any double/tripleshot keycaps. The same holds true for dyesubbed & UV printed caps, but I tend to be a little more forging with the printed legends compared to double/tripleshot legends.
Offline KeyCapQueen
« Reply #2 on: Mon, 27 March 2023, 08:05:37 »
Thank you very much for the explanation. Is the harshness (or edge sharpness) of the keycaps edge something that people care about?
Offline Rob27shred
« Reply #3 on: Mon, 27 March 2023, 09:28:21 »
No problem, some people care about the sharpness/smoothness of the corners but I would put that down to more a preference thing. Unless the cap is wonky looking or something cause of its edges.
