Author Topic: Das model S silent or Filco Majestouch  (Read 4593 times)
Offline yayitsdan
« on: Thu, 07 October 2010, 09:45:46 »
I'm pretty much forced to sell my model M13 because it doesn't have a windows key (I use a usb switch between my pc and mac, mac requires it for shortcuts) and I'm in the market for a new keyboard. I don't want to spend much more than $130 and I'm going to be doing a lot of typing and gaming with it. After some research, I think I'll be happy with cherry browns.
Right now I'm going between these two keyboards
Das model S silent
Filco Majestouch
A USB hub is a pretty big plus for me and the Filco doesn't have one. I don't mind spending a little more for the Das keyboard, but I also want to get the best for my money. I'm just under the impression that Filco makes better keyboards. Is there a big difference between these two?
Offline itlnstln
« Reply #1 on: Thu, 07 October 2010, 09:53:16 »
No, they're made by the same OEM.  Get the one you think looks better/has better features.
Offline MissileMike
« Reply #2 on: Thu, 07 October 2010, 10:23:05 »
I had the same choice, and I chose the filco because of the das glossy finish.  I prefer matte on a keyboard.  You can't go wrong with either one, though.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline frvrngn
« Reply #3 on: Thu, 07 October 2010, 10:30:33 »
Are you a student/teacher?  If so, you can get a discount from DAS.  Just email them and they will let you know what they need.
Currently using: Cherry G80-1800 Ergo Clears, HHKB Pro 2, RF 87U Silent
Offline itlnstln
« Reply #4 on: Thu, 07 October 2010, 10:34:00 »
Quote from: ripster;230836
Arggghhhhh.....
Asustek, Inventec Appliances and Foxconn make the iPod.  I don't spend a lot of time researching which one makes mine.
They also make lots of other stuff.
I thought you knew all this from the food biz?  ODM versus OEM versus....  It's inside what counts (including firmware).
Everyone's favorite kicking bag of 2009.  The Das 3 controller.  The Filco is different.  I haven't seen the Das S taken apart yet.
Switches, structure, and feel are all about the same and that's what counts.  Firmware is intangible, and you only really know the difference if it doesn't work.  If it comes from the same OEM/ODM and the overall structure is the same, then really the only difference is features and looks.
Offline MissileMike
« Reply #5 on: Thu, 07 October 2010, 10:34:08 »
...or sometimes das also has a coupon code.
Offline keyboardlover
« Reply #6 on: Thu, 07 October 2010, 10:51:38 »
Isn't one PCB-mounted and one Plate-mounted? Doesn't that cause a difference in feel?
Offline itlnstln
« Reply #7 on: Thu, 07 October 2010, 10:59:16 »
Quote from: keyboardlover;230857
No, they're both plate-mounted (AFAIK, only Cherry uses PCB-mounting).  If you read Ripster's comparison, he mentions he doesn't feel much difference between the two.
This might help, too: http://www.costar.com.tw/products01/?p_sid=32
Offline Senor_Cartmenez
« Reply #8 on: Thu, 07 October 2010, 11:28:39 »
Quote from: frvrngn;230848
also have 2 b not in europe
read ripster's das vs filco thread
major turnoff das: shiny surface
major turnoff filco: no extras
major turnoff both: no double shot keycaps, no BL
perfect keyboard? here
Offline yayitsdan
« Reply #9 on: Thu, 07 October 2010, 12:32:01 »
Thanks guys. I decided to go with the Das because of the usb hub. I can't want to get ahold of it. Hopefully I'll like it just as much as my M13.
Offline itlnstln
« Reply #10 on: Thu, 07 October 2010, 12:39:09 »
Good choice.  Enjoy.
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #11 on: Thu, 07 October 2010, 15:20:40 »
You could have just used auto hot key modifier to get your win key action.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
