Author Topic: [GB] FjordBoard; A 75%-ish keyboard with a slider| MOQ not reached :(  (Read 9160 times)
Offline Frugivore
297734-0
297736-1
This project did not hit MOQ
Specs
Top-mounted Modified 75% layout
Customizable MIDI Slider
CNC aluminum case (6063)
0.5 kg brass weight
Total built weight 2.12 kg
Pantone 533 C blue
5° typing angle
Full Vial, VIA, and QMK functionality/support
Included FR4 plate with available plate files.
Hot-swappable PCB with support for ANSI and ISO
Controls system volume on Windows, Mac, and Linux
Group Buy Details
Start date: April 28th 2023
End date: May 12th (two weeks from start)
350 USD, exact per vendor pricing on each page
The fulfillment date dependent on sales, no less than 3 1/2 months, and unless the GB goes crazy with sales numbers should be no more than 5 months.
Vendors
US-Dangkeebs
UK and EU- Proto[Typist]
OCE- Allcaps
JP- Basekeys
Vietnam- Uniqmeck
SEA and China-Hex Keyboards
Canada-Desk Hero
Proto Pics
297738-4
297719-5     297721-6
297723-7     297725-8
297727-9     297729-10
The Sound Test
Conservation of Fjords
Some portion of the proceeds will be donated to Kākāpō recovery. Kākāpōs, flightless ground parrots, are highly endangered. The fjords of New Zealand are some of the few places they still survive.
IC page
https://geekhack.org/index.php?topic=116532.0
Add this to your signature to show your support!
Code: [Select]
[url=https://geekhack.org/index.php?topic=119903.0][img width=540 height=120]https://i.imgur.com/f0WLwEP.png[/img][/url]
FjordBoard is a product of Bears and Companies LLC of Virginia; Designed by Frugivore
« Last Edit: Wed, 17 May 2023, 16:13:07 by Frugivore »
Offline Frugivore
Re: [GB] FjordBoard; A 75%-ish keyboard with a slider| GB page launch
« Reply #1 on: Sun, 26 March 2023, 11:02:39 »
Updates
4/21/23: Added Desk hero for CA vendor.
« Last Edit: Fri, 21 April 2023, 07:40:36 by Frugivore »
« Reply #2 on: Fri, 14 April 2023, 11:45:50 »
Approved :thumb: (est fulfillment date to be added shortly)
Offline tjmaXXX
« Reply #3 on: Thu, 20 April 2023, 19:09:51 »
finally made an account just to say:
Reader, this is the VG65, but worse and more expensive. GLWS
Offline Frugivore
« Reply #4 on: Thu, 20 April 2023, 19:40:28 »
The VG65 is an amazing board for sure, I think the boards are different enough that they can peacefully coexist :)
Offline The Japple
  • PC/Keyboard enthusiast, techy, Essentials designer
Re: [GB] FjordBoard; A 75%-ish keyboard with a slider| LIVE NOW!
« Reply #5 on: Sat, 29 April 2023, 16:20:22 »
I've been following the project for a few months now. Frugivore has been open to feedback, quick to respond, and kept everyone updated on the status of things.
It's quite a pretty board, and after watching Alexotos's stream last night, I can say it sounds quite nice as well! That layout has really grown on me. I'd get one for myself without hesitation if I was looking for another keyboard right now.
GLWGB!
If it ain't broke, fix it 'till it is
