Author Topic: [CLOSED][GB] GLOVE x Domikey CHOCO Donuts Keycaps groupbuy  (Read 30598 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Sun, 26 March 2023, 22:16:04 »
SPEC
Cherry profile
Doubleshot / tripleshot
ABS keycap
GB close on 10th Apr (PST)
Estimated delivery in JULY
JOIN THE GB NOW
KEYCAPS
In his dounghnut, GLOVE pours a spoon of chocolate and spreads some candies.
To finish his donuts, GLOVE works with Domikey and use doubleshot and tripleshot to make the keycaps available.
GLOVE prepares three different donuts: strawberry mixes Matcha, Litchi mixes orange and Blueberry mixes Grape.
In order to create the scratter looking, GLVOE draws the mixed colour alpha with the rule of three colour map theorem (three colours aren't adjacent to each other). He gets three different mixed colour Alpha kits based on the three single colour Alpha kits.
« Last Edit: Sat, 15 April 2023, 00:43:21 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] GLOVE x Domikey CHOCO Donuts Keycaps groupbuy
« Reply #1 on: Sun, 26 March 2023, 22:16:51 »
ASSOCIATED THEME SWITCH
GLOVE also prepares specific associated switch for Donuts theme. The switch is a light actuation force Linear switch.
Light-Act-force Linear switch
around 22mm 2-stage spring
Actuation Force 40g
Bottom Force 45g
Total Travel 3.8mm
All POM switch
100 million clicks
Factory lubed
Manued by HaiMu Electronic
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Sun, 26 March 2023, 22:17:36 »
ASSOCIATED THEME MOUSEPAD
The Donuts mousepad won't be missed for sure.
Rubbersized fabric
pad printing
stitch edge
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #3 on: Sun, 26 March 2023, 22:18:00 »
ASSOCIATED THEME CABLE
GLOVE works with win shop and creates Donuts cables as well. Now, you can get a complete Donut style, from keycaps to cable and mousepad.
SPEC
Type-C cable
around 150 cm
coiled part around 19cm
straight par around 120cm
WinShop customized aviator connector
Snakeskin gleeve and paracord weaves
