Author Topic: [GB] Treasure TRAY | Modular Tray for screws and artisans  (Read 3518 times)
Offline Treasure
  • Industrial Designer / Inventor / Maker
    • Design & Eng
« on: Tue, 28 March 2023, 14:44:08 »
Interest check : https://geekhack.org/index.php?topic=119608.msg3154888#msg3154888
Treasure TRAY ( Or "Traysure" ) is an aluminum modular tray, with a silicone insert to expand the tray possibilities
Sort your keycaps, screws, SD Cards, springs, and small items with style
Designed with the Treasure® design language
You can use it with or without the silicone insert.
Features
Whats in the box
        1x Aluminum Case
        1x Silicone insert
        2x Silicone feet
Dimensions
   69 x 69 x 19 mm
Finishes and Info
        Aluminum Finishes
                White ( E-Coating )
                Matte Black
                Purple
        Silicone Insert colors
                International Orange
                Black
Prices
Treasure TRAY    : $33
Extra silicone insert     : $8
Group Buy Opens: March 24th, 2023 @ 07:00PM CET ( Duration: 1 month )
Estimated Ship Date: Q3 2023
>> GROUP BUY <<
« Last Edit: Tue, 28 March 2023, 14:46:14 by Treasure »
Re: [GB] Treasure TRAY | Modular Tray for screws and artisans
« Reply #1 on: Thu, 30 March 2023, 11:04:18 »
Approved :thumb:
Offline Treasure
    • Design & Eng
« Reply #2 on: Wed, 05 April 2023, 03:33:43 »
Thanks !
Offline Treasure
    • Design & Eng
« Reply #3 on: Mon, 24 April 2023, 14:03:06 »
Last day to pre-order your Treasure TRAY 🔥
Aluminum modular tray with a silicone insert
Available exclusively though our website :
https://treasuretypes.com/products/tray
