Author Topic: Modding a JAP Layout to ISO? Only Spacebar/DEL key  (Read 1750 times)
Offline ~Blood~
« on: Thu, 07 October 2010, 13:29:47 »
Is a mod like that possible without much effort?
The layout is very similar, only the DEL key is smaller and the spacebar is tiny.
I'd plan to remove the Kana Keys next to the space bar and put a large spacebar there, remove the small key next to the DEL key and put a large DEL key there.
Probably my only option of getting an all 45g/30g topre with ISO layout :/
« Reply #1 on: Thu, 07 October 2010, 15:29:16 »
As far as I know, only the IBM buckling spring keyboards and perhaps a few KeyTronic keyboards could be modded to a different layout. They use the same membrane/PCB for all layouts and have two plungers underneath those keys that are wider in some layouts than others.
However, most keyboards have the switch in the centers of all wide key, and so do the Realforce keyboards, as far as I have seen. I think also that the Realforce PCBs are unique for each layout (ISO/ANSI/JIS).
Besides the Kana and Del keys, the Left Shift key is one unit bigger and the Right Shift is one unit smaller in the JIS layout compared to ISO layout.
Offline netwebber
« Reply #2 on: Mon, 11 October 2010, 03:35:02 »
A JAP types as little as possible. She might break a nail!
Keyboards: IBM M15 adjustable ergonomic | Northgate Omnikey Evolution w/ Touchpad | IBM Model M 1391401 | TG3 BLT 5RBUVS tenkeyless | MS Natural Keyboard Pro | MS Natural Keyboard Original (Black) | IBM UltraNav Travel Slim Keyboard | Chicony ThinkPad T60 keyboard in Lenovo ThinkPad T400 | IBM ThinkPad T42p | MS Arc Wireless | Logitech K350 Wireless
Pointing Devices: Logitech G500 | Logitech Anywhere Mouse MX | IBM ScrollPoint Optical | Razer Boomslang | On laptops: Trackpoint for pointing, touchpad for scrolling--The True Way
Other: Belkin/Razer Speedpad n52te | Adesso Mechanical Numpad (Cherry Blues) | Wacom Intuos2
Game Controllers: MS Sidewinder Force Feedback Pro | Gravis Exterminator
