Author Topic: Are there any open-source hot-swap keyboard PCB that fits the Bakeneko60 case?  (Read 9485 times)
Offline Im_Pigeon
Hi, Just thought I would ask if there are any open-source hot-swap keyboard PCB that fits the Bakeneko60 case, before I go the stock + Mill-Max path.
Offline Applet
If you don't solder the USB-port on the tray mount PCB in my waffling60 project, it fits the Bakeneko (both V1 and V3 mount): https://github.com/4pplet/waffling60
There is a hotswap ANSI version in releases, I need to update the readme. If you buy one from 4pplet.com I can remove the USB-port prior to shipping.
Offline Im_Pigeon
Glorious ISO layout too!
