Author Topic: Custom Keyboard Design Services (PCBs, Cases, etc.)  (Read 31278 times)
Offline anonymous
« on: Tue, 11 April 2023, 23:54:27 »
Greetings, this is DeskDaily and we specialize in designing customized keyboard Printed Circuit Boards (PCBs) and cases. Whether you require custom designs for personal or commercial purposes, we are equipped to provide you with tailored solutions. Additional information regarding our services can be found below, as well as on our website, www.deskdaily.design
What we can do:
  • Case Design
  • Plate Design
  • PCB Design
  • Firmware Creation/Compiling (QMK/VIA/VIAL)
  • Keycap Design (Engraved/Embossed Design)
  • Foam Design (Case Foam, Plate Foam, Keyboard Case Foam)
For Case Designs, we can do:
  • Stacked Acrylic Case Designs
  • CNC Machinable Case Designs (which can be slightly modified to be suitable for 3D printing)
For PCB Designs, we can do:
  • Any layout
  • Any switch footprint
  • Any shape, or if you want to integrate the case mounting points to the pcb
  • Wired using USB-C and/or JST Connectors/Daughterboard (can't do bluetooth for now)
  • RGB Underglow or per-key RGB
  • Rotary Encoders
  • OLED
  • Flex-Cuts
  • QMK/VIA/VIAL Firmware
PCB Design Packages
1) Personal PCB Package (Physical PCBs w/o Source Code)
We will design a personalized PCB for you; however, you will not be provided with the digital design files, but only with the physical PCBs (5pcs). Firmware and 3D model of the pcb will be provided.
Perfect for those who only need a few PCBs for personal use.
2) Full PCB Digital Design Package
We can create a personalized PCB for you and provide you with the source files, gerber files, production files (BOM and CPL), firmware, and a 3D model of the PCB.
We will not provide physical copies of the PCB, but we can assist you with instructions on how to order them independently.
You have complete freedom to use the design files as you wish, including for commercial purposes.
Pricing:
Our pricing structure is based on a case-by-case evaluation. To provide you with an accurate quotation, we require a thorough understanding of your design requirements.
If you have any questions or would like to request a quote, please don't hesitate to contact us. Thank you for considering DeskDaily for your custom keyboard design needs.
Contact Information:
Discord: DeskDaily#3249 or anonymous#1185
Email: deskdailyco@gmail.com
Re: Custom Keyboard Design Services (PCBs, Cases, etc.)
« Reply #1 on: Thu, 13 April 2023, 11:09:39 »
Approval bump :thumb:
Offline TerraKeycaps
« Reply #2 on: Sun, 30 April 2023, 07:36:50 »
+ Vouch, have worked with DeskDaily  :thumb:
