Author Topic: Mod Mmm PCB for the IBM Model M  (Read 5717 times)
Offline dcpedit
« on: Tue, 18 April 2023, 11:51:52 »
Long time lurker here, but first time poster!  Wanted to let every know that my new project is now on Github which allows you to use a PCB inside of an IBM Model M case!
https://github.com/dcpedit/mod-mmm
Here's the list of features:
  • Hotswap sockets for MX switches
  • Multiple layout support, including ISO, split spacebar, and 4x5 numpad. KLE link
  • PCB mount stabalizers
  • Under-switch LED for caps, scroll, and num lock
  • Supports up to 3 rotary encoders
  • Piezo buzzer
  • Solenoid
  • USB-C support via the STM32F411 Blackpill dev board.  Possibility of upgrading to the Bluetooth PillBug.
  • Vial firmware
Also including some dev notes if you want to read them:
PCB curvature:  The curvature radius of the Model M's steel backplate is about 10.9 inches.  Flexible PCBs are super expensive, so for this prototype I opted for thinner FR4.  The risk is that traces/pads could break, and components can become damaged due to the stress placed on the board.  Converting all the components to through-hole might help mitigate this issue, and hopefully the large radius of the curve will cause less stress.
FR4 thickness:  Too thick, and it will be difficult to bend.  But too thin, and the hotswap sockets and stabilizers won't fit well.  I felt 1mm was a good compromise.
MCU board: I settled on the SMT32F114 Blackpill since it has the most usable pins in a form factor that fit on the daughterboard (I used EVERY SINGLE pin).  I was hoping that once the PillBug from MechWild came out, it could easily be converted to wireless.
Stabalizers:  I was worried that the curvature of the PCB would not work with PCB mount stabs.  I made the mount holes a tad bigger in the vertical direction to give them some more wiggle room, and it seems to work OK.
Hot swap sockets:  It was easier to test things during development with hot swap, but the sockets themselves did not provide enough holding power to keep the switches stable (at least with 3 pin switches).  I decided to design a plate for this iteration, which in turn also required plate foam.  Converting the switch sockets to solder-only could allow for more stable plateless builds.
Reddit discussion here
Offline Crabtree223
Re: Mod Mmm PCB for the IBM Model M
« Reply #1 on: Wed, 19 April 2023, 05:11:49 »
https://github.com/dcpedit/mod-mmmuno online
  • Piezo buzzer
  • Solenoid
  • Vial firmware
Even though I like the way the buckling springs feel and sound, I couldn't use them on a regular basis because of how heavy they are. This is particularly true given that I used to have repetitive stress injury (RSI). However, I am still partial to the more traditional appearance of the Model M, which is why I decided to create this modification. I am now able to use dimmer switches!
