Author Topic: Four Budget( 0.25USD)Switches but also has a "HIFI" Sound !  (Read 7121 times)
Offline Aregs Keyboard
Updated:
Reviews:
The portly gamer:https://youtu.be/Hu3ta7FcyoI
Maker Mods:https://youtu.be/wXJscLv4RsA
Tofutype:https://youtu.be/a1DFbmtbQWM
Hello! I'm Aregs, and I'm happy to present Four our very proud switches here!
As you can see, the most fascinating thing is their springs, they're actually coloured! It's crazy isn't it? They have a great feel and a great sound and are priced at just 0.25USD/Pcs!
They are designed and produced by G-Square and NLandkeys and manufactured by us at Grain Gold!
They are White Samurai, Dark Night,DreamLand(Linear) and DreamLand(Tactile)
Here are their details:
White Samurai and DreamLand(Linear)
298670-0298676-1
(They have the same details only different with Colour)
TYPE: Linear Switches
MOUNT: 5-pin bottom case (PCB MOUNT)
MATERIAL:
Stem: Reinforce POM
TOP: PC
Bottom: Nylon
3.2mm±0.3mm travel /2.0mm±0.3mm
Spring: 58g (bottom out) Double spring
42g actuation
Reinforce POM stem (“reinforced” means adding additives into raw material. Enhances stiffness while keeping the smoothness. More steady, more “Hifi”)
Sound Test:
(They has a same sound when typing)
t=79s
   (Sound Test at 8:50)
Dark Night and DreamLand(Tactile):
298672-2298674-3
(They have the same details but different with Colour and Springs)
TYPE: Tactile switches
MATERIAL:
  Stem: Reinforce POM
TOP: PC
Bottom: Nylon
Springs:
Dark night:
62g (bottom out) Double spring
43g actuation
DreamLand(Tactile)
42g actuation
Sound Test:
Manufacture: Grain Gold
Price:0.25USD
In Stock:www.nlandkeys.com
Sells Date: 5/10
If you are interested in this product, Please join our discord: https://discord.gg/3zeEu5mxBn
« Last Edit: Sat, 10 June 2023, 12:21:05 by Aregs Keyboard »
Offline mr_foggy
  • neue = nope
Re: Four Budget( 0.25USD)Switches but also has a "HIFI" Sound !
« Reply #1 on: Thu, 27 April 2023, 04:05:56 »
no regional vendors?
« Reply #2 on: Thu, 27 April 2023, 04:28:29 »
We would like to sell the first batch on our own website and the shipping cost is only about 3-5 USD, is this price acceptable? There will be a regional distributor later, but after the first batch
Offline The0rigina1
  • fumoposting
« Reply #3 on: Thu, 27 April 2023, 05:06:13 »
3.2mm travel  :-\
« Reply #4 on: Thu, 27 April 2023, 05:11:20 »
3.2mm travel  :-\
Haha,you should have a try, it is crazy haha
Offline mr_foggy
  • neue = nope
« Reply #5 on: Thu, 27 April 2023, 05:34:07 »
awesome then, will pick them up from you directly  :thumb:
Offline Robert.Lussier5
« Reply #6 on: Thu, 27 April 2023, 06:17:20 »
Any sound test without pe foam or poron foam?
Those types of sheets significantly alter switches to all basically sound the same to an extent.
Austin R3 - Green // Austin R3 - Purple // Custom Acrylic Austin - Clear // Rekt1800 - Blue // Cypher r4 - Black // Boston - Sparkle Black // Balance - White // Glitch - Green // Shelby80 - Navy // Odin - Silver // Zoom65  Red // QK65 - Black // Link65 - Lilac
Offline alper_maestro
« Reply #7 on: Thu, 27 April 2023, 08:05:37 »
Are those pre-lubed as well?
Offline Rhienfo
  • GOTHETIGES
« Reply #8 on: Thu, 27 April 2023, 14:17:07 »
really appreciate more budget switches, 3.2mm is kinda wild but it's still interesting.
« Reply #9 on: Fri, 28 April 2023, 06:37:58 »
Yes,they are pre-lubed
« Reply #10 on: Sat, 10 June 2023, 12:21:23 »
Updated:
Reviews:
MATERIAL:
Stem: Reinforce POM
TOP: PC
Bottom: Nylon
42g actuation
Sound Test:
t=79s
MATERIAL:
  Stem: Reinforce POM
TOP: PC
Bottom: Nylon
Springs:
Dark night:
43g actuation
DreamLand(Tactile)
42g actuation
Sound Test:
Price:0.25USD
Sells Date: 5/10
Upated reviews
