Author Topic: [GB] SLK Dessau Light and Dark (Replacement keys shipped to vendors)  (Read 44337 times)
Offline kema
  • Designer
    • kevinmadesign
SLKDessau.com↗
https://fkcaps.com/keycaps/slk/dessau↗
Vendors and Pricing
Cannon Keys (US)↗
Deskhero (CA)↗
zFrontier (CN)↗
zFrontier (AS)↗
Yushakobo (JP)↗
Aiglatson Studio (TH)↗
Candykeys (EU)↗
ProtoTypist (UK)↗
SwitchKeys (AU)↗
Kit                       USD              CAD              CNY              JPY              THB              EUR              GBP              AUD
Base Kit$99$144¥749¥15,290฿3,550€112£99$160
Compact Kit$40$58¥299¥6,160฿1,450€44£40$65
Int'l & Misc$40$58299¥6,160฿1,450€44£40$65
Group Buy from May 1st, 2023 to June 1st, 2023
Delivery to vendors in December 2023
About SLK profile
SLK is a new uniform profile designed by Synth Labs, with the goal of making an aesthetically modern, low-profile option for MX-style switches.
• Round top keycaps with capsule-shaped dish cutaways and tapered base
• 1.5mm PBT plastic with dye-sub and reverse dye-sub legends
• Supports ISO enter and stepped caps lock
• Produced by FK Caps
Design and Kits
The legends feature a modern monoline typeface with a number of base glyphs modified for a more cohesive look and feel.
Rather than keeping the original monospacing, each legend has been carefully kerned to read better in this context.
Edge modifier legends are also edge aligned both for aesthetics and so the legends can still be read when partially obscured by your hands.
Choose between Light and Dark colorways.
Colors represented are approximations of physical samples.
Lighting will affect final appearance.
Base Kits
Compact Kits
International & Misc Kits
Renders
Renders by @its.hymn↗
Collaborations
Turbulent Labs
A collection of handmade full-grain Italian napa leather desk accessories. Available in matching light and dark colors.
HIBI Lens Keycap
Protozoa Knob
Fits common encoders with 6mm shaft, 18.2mm diameter
Links
Follow kema on IG @kev.nma↗
Follow Synth Labs on IG @synthlabsmk↗
Follow FK Caps on IG  @fk.caps↗
Join the Synth Labs Discord: https://discord.gg/FCmrQ75rny
« Last Edit: Thu, 29 August 2024, 20:40:20 by kema »
Re: [GB] SLK Dessau Light and Dark (May 1st – June 1st)
« Reply #1 on: Mon, 01 May 2023, 13:49:24 »
Approved :thumb:
Offline phxrbn
  • tech. design. real estate.
« Reply #2 on: Mon, 01 May 2023, 14:53:21 »
none of the vendor links seem to be working.
Offline kema
  • Designer
    • kevinmadesign
« Reply #3 on: Mon, 01 May 2023, 15:49:11 »
Linked the vendors that are currently live !
Deskhero, CandyKeys, Prototypist, and SwitchKeys will be up soon and I'll link those when live
All vendors live now!
« Last Edit: Wed, 03 May 2023, 11:28:51 by kema »
Offline patcoll
  • !40s
« Reply #4 on: Tue, 02 May 2023, 11:12:11 »
What's the measurement of the outer diameter of the knobs? Can't find their specs anywhere.
Offline Nostril
  • Synth Labs
« Reply #5 on: Tue, 02 May 2023, 18:05:53 »
Hey! The outer diameter of the Protozoa knob is 18.2mm.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #6 on: Wed, 10 May 2023, 23:32:34 »
Edit: revised x axis scale to match final
« Last Edit: Sat, 08 July 2023, 14:13:47 by dvorcol »
Offline Gimbal
« Reply #7 on: Thu, 11 May 2023, 07:00:34 »
Very interesting.
Do we know if they work with Kailh Choc V2 low profile switches?
It would be a sweet combination for a low profile keyboard. But some keycaps are slightly to narrow inside and sort of rubs on the case of the switches.
Offline Nostril
  • Synth Labs
« Reply #8 on: Thu, 11 May 2023, 13:52:28 »
Very interesting.
So the SLK profile is designed with MX-style switches (regular profile/height) in mind, but I've also tested SLK out with Kailh Choc V2s, as well as several other low-profile switches.
Kailh Choc V2s, GTMX Mids, and Gateron KS-27s all had no interference with the switch, but it would collide with the plate. So it could be used in plateless builds with these switches.
Tecsee Mediums were the only switch I encountered which had interference with the switch itself.
And of course, I've tested it with a wide variety of regular-profile MX-style switches from pretty much all the major manufacturers. Any of these switches should be perfectly compatible with SLK in any build, plate or plateless, any stabs, etc.
« Last Edit: Thu, 11 May 2023, 13:57:03 by Nostril »
Offline Gimbal
« Reply #9 on: Fri, 12 May 2023, 01:55:52 »
Great. :thumb:
 I'm in.
Offline kema
  • Designer
    • kevinmadesign
« Reply #10 on: Tue, 23 May 2023, 22:24:23 »
Update on the HIBI Lens keycap, prototypes of the clear resin infill didn't work out as intended so we'll be removing the clear infill (keeping the small black infill at the center of the lens). I think this will still look great and the dish/cup with the texture will be really nice!
Vendors will send out comms about the change at the end of the GB and allow those who dislike the change to cancel 🙏
Offline Nuap
« Reply #11 on: Fri, 26 May 2023, 01:30:40 »
Is there an MOQ for the caps?
Offline kema
  • Designer
    • kevinmadesign
« Reply #12 on: Mon, 29 May 2023, 17:48:43 »
No hard MOQs on the keycaps
Offline kema
  • Designer
    • kevinmadesign
« Reply #13 on: Mon, 29 May 2023, 17:50:17 »
Typing test with SLK production blanks from Nostril !
Offline Gimbal
« Reply #14 on: Wed, 14 June 2023, 09:14:27 »
So is everything moving forward as planned, or what is happening?
Offline kema
  • Designer
    • kevinmadesign
« Reply #15 on: Sat, 17 June 2023, 23:06:20 »
Yes, orders are being placed and production samples are being iterated on! I received the first set of them couple of weeks ago and the colors look great, but legend alignment needs to be improved.
Offline Gimbal
Re: [GB] SLK Dessau Light and Dark (GB Closed)
« Reply #16 on: Mon, 19 June 2023, 02:41:38 »
 :thumb:
Offline dvorcol
« Reply #17 on: Sat, 08 July 2023, 14:03:19 »
Offline kema
  • Designer
    • kevinmadesign
« Reply #18 on: Tue, 26 September 2023, 01:32:51 »
Hey all, quick update – after 5-6 rounds of just the light grey color, color matching for the whole set has been completed.
The "ESC" key is the grey that more closely matches the renders but IRL seems a tad darker than I'd like. The "ENTER" example has a slightly lighter grey mix that I think matches up more nicely to the white and is the one I've chosen to move forward with. I'll also be sending these samples to Cannon Keys to get their thoughts on them.
Next steps will be working on full kits of master samples and making sure alignment and dyesub quality are there.
Making progress!
Offline kema
  • Designer
    • kevinmadesign
« Reply #19 on: Sat, 03 February 2024, 14:07:09 »
Light theme kits are production complete, dark theme kits should be at about 90% completion with the remainder being done post-Chinese New Year holiday and everything shipped to vendors at the start of March.
The delay is due to some keys not meeting our QC guidelines and thus being remade, but we stressed to the manufacturer that quality should absolutely come before speed so this is nice to see from my perspective.
Offline kema
  • Designer
    • kevinmadesign
Re: [GB] SLK Dessau Light and Dark (Shipping)
« Reply #20 on: Mon, 25 March 2024, 22:28:13 »
Re: Dyesub issues and replacement keys
Hey all, the keysets are now shipping to buyers and this is disappointing to say the least, but despite the many rounds of sampling/feedback, strict QC documentation that the manufacturer agreed to (which precisely details the alignments we require), and even having a member of our team on-site for a week to oversee the production, many of the dark production samples and some of the light ones shipped with unacceptable legend alignments. I'm not sure if they were rushing or chose to forego the QC guidelines they agreed to, but I know myself and FK Caps want to make things right. So please reach out to your vendors with a list of flawed keys you'd like replaced. They'll pass on those details to FK Caps and the manufacturer to get new keys remade and sent out to ya'll.
Offline vhaarr
« Reply #21 on: Thu, 28 March 2024, 02:35:19 »
Very nice post, I hope all goes well and that we see more of SLK soon :-) Can't wait for extras!
If anyone wants to see the misaligned keys, there's a post here https://old.reddit.com/r/MechanicalKeyboards/comments/1bpjick/diy_board_with_slk_dessau_keycaps/ with some photos.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline lastkey
« Reply #22 on: Mon, 20 May 2024, 22:37:51 »
What a disaster. Numerous keycaps in my base sets with horrible legend alignment.
Offline Narcolepsy
« Reply #23 on: Mon, 20 May 2024, 23:33:31 »
Which vendor did you buy from? The manu will be remaking misaligned keys free of charge. The vendor should have sent communication out to you so you can let them know which of your keycaps are affected to get replaced.
Offline lastkey
« Reply #24 on: Tue, 21 May 2024, 10:32:14 »
Already submitted to CK. Timeline and whole process wasn’t worth the money to me even with the free replacements. Shouldn’t have been shipped.
Offline jedmund
« Reply #25 on: Sat, 25 May 2024, 04:14:48 »
The problem that I have is that there are so many misaligned legends that I legitimately can't tell what is the normal, intended alignment.
I bought Light, Dark, and the Int'l variants of each and Dark seems to have way more misaligned legends. I currently have a note of 40+ keys across my sets that need replacement but I have to go through and take pictures for the replacement process, which is not going to be fun.
Offline ItIsWritten
« Reply #26 on: Sat, 25 May 2024, 09:10:47 »
Since the keys will be misaligned for everybody the same, can't they just make replacements for all sets? Do we really all have to find the separate keys ourselves?
Verstuurd vanaf mijn SM-G986B met Tapatalk
Offline kema
  • Designer
    • kevinmadesign
« Reply #27 on: Sun, 26 May 2024, 16:09:45 »
Afaik keycaps are dyesubbed in batches so not every set will have the same alignment issues.
FK Caps and vendors have been QCing the sets they've received and compiling buyer reports and production on the replacement keys has been started, estimated to ship to vendors late June.
A member of the FK team will also be at the factory towards the end of production to QC the sets and make sure we don't send out wonky keys again.
Offline ItIsWritten
Re: [GB] SLK Dessau Light and Dark (Replacement keys in production)
« Reply #28 on: Sun, 26 May 2024, 16:37:15 »
That's great, but like the person above I'm probably looking at getting 40+ keys replaced, and I even haven't received my sets yet. Hopefully I won't miss any.
Offline Gimbal
« Reply #29 on: Tue, 11 June 2024, 12:33:54 »
I just received my order, light base + international and they look great.
Very nice design, nice texture and even nice packaging, the alignment is pretty good as well. (Perhaps one or two that could have been adjusted very slightly, but not so much that it bothers me). And it seems to work nicely with Kailh choc v2 low profile switches. I'm happy.
So  :thumb:
Offline BraunEsc
« Reply #30 on: Mon, 19 August 2024, 05:18:52 »
What about the Protozoa Knobs?
I’ve still not received anything due to the missing knob.
Offline lastkey
« Reply #31 on: Fri, 23 August 2024, 09:51:47 »
Still waiting on replacement keycaps with no ETA in sight...
Offline BraunEsc
« Reply #32 on: Fri, 23 August 2024, 16:44:14 »
Yeah pretty big **** show tbh.
Communication has been really bad for month no sign of nothingness. No date for the knob. Reputation for this and future jobs: 0
Earned the red flag sign!
Offline kema
  • Designer
    • kevinmadesign
« Reply #33 on: Thu, 29 August 2024, 20:40:06 »
Received my replacement keycaps direct from the manufacturer and the light kits are virtually errorless (the few accented keys in the Int'l + Misc kit I have are oddly aligned), very happy with these ones now.
The dark kits are much improved but still has some keys here and there that are still slightly off alignment, but overall more usable (don't see any alignment issues with the alphas aside from the accented keys again). I highly recommend double-checking your dark kit replacement keys and reach out once again to your vendors if there's anything wonky to get another replacement. However, vendors seem to be QCing all the replacements by hand, so you may be receiving better examples than myself. :fingers_crossed: :fingers_crossed:
If FK Caps ever reruns the Dessau design in the future, I can't imagine going with this same manufacturer with all the errors and headache.
Re: Protozoa knobs, I've requested another update to see what's going on, I was told they just needed to tap the knobs for the screw but I'm unsure why I haven't heard anything in the past month.
Offline ANTICATER
Re: [GB] SLK Dessau Light and Dark (Replacement keys shipped to vendors)
« Reply #34 on: Sat, 31 August 2024, 03:51:29 »
good
Products as People
Offline kema
  • Designer
    • kevinmadesign
« Reply #35 on: Wed, 11 September 2024, 19:46:43 »
Heard back from Protozoa last week that the knobs were completed and all packed up, I assume they've been shipped out to vendors by now
edit 9/19: seems like they haven't shipped yet and Protozoa has been unresponsive, will update once I know more
« Last Edit: Thu, 19 September 2024, 22:59:49 by kema »
Offline BraunEsc
« Reply #36 on: Wed, 06 November 2024, 08:48:55 »
Another nearly 2 month since last update. Any news?
Offline BraunEsc
« Reply #37 on: Wed, 07 January 2026, 00:04:07 »
Comming 3 years niw - still waiting for the fulfilment of my order! This is shameful.
Offline Nostril
  • Synth Labs
« Reply #38 on: Wed, 07 January 2026, 03:36:29 »
It's been about a full year since everything was fully fulfilled, including the replacement runs, and the Protozoa knobs which did get severely delayed. I'm really sorry that the process wasn't exactly a smooth one, but at this point, production ended long ago. If you haven't received the set yet, I'd recommend to check in and reach out to the vendor that you ordered from to request a refund. If you run into any trouble in doing so, feel free to reach out to me on Discord: @nostril
